Question about Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
The oven heats up but stops a 200 degress - Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Ben,
I see that you are having trouble with your dual fuel range, model# PLCF489AC, heating up past 200 degrees. It sounds like it could possibly be something to do with your control board or your oven thermostat. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your range, if it still will not heat up past 200 degrees, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Posted on Apr 22, 2014
Turned oven to 350 degress but it wont go past 200 degress please help
Ben, the most common failure for this range is the oven temp sensor. Part # 316490001. Sensor is accessible from the back of the range. turn off power, remove the sensor and check the resistance of the sensor you have now in a glass of ice water (12 oz) mixed with one tablespoon full of salt, well dissolved. you should read approx 1000 ohms +/- 4.0 If you are outside of this value, replace the sensor.
Apr 18, 2014 | Frigidaire PLCF489AC Dual Fuel (Electric...
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Oven does not work , the element doesnt glow and the temp never reaches above 100 degress
oven display element supply all working perfectly
only 1 problem i face oven did not heat up...
plz help me quickly
thank you
Regarded
Hannan Ashraf
Sep 02, 2011 | GE Profile JK915 Electric Single Oven
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven temperature adjustment
well no need to fret, if you oven is heating over 100 degress off theres problably not an adjusatment to compensate for that, youll need to either replace the htermostat or the thermistor, depending on which your machin uses
Jan 18, 2009 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range Logo
115 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
