Question about Brother Entrepreneur Pr 650 Embroidery Machine With Hoops & Frames
Needle threader misses eye of needle 3, how can this be fixed
Needle threader missing the eye of needle 3 how do I fix or adjust.
  • 77 Answers
There is a small wire hook that, when utilized, pokes through the eye of the needle. Several issues can occur. 1) Wire is bent slightly (use fingernail to move the wire to realign with needle) 2) hook is broken on wire (repair shop) 3) needle not fully inserted in slot
Posted on Apr 23, 2014
Brother VQ 2400 can't get needle threader to work. Re-thread machine& changed needle still will not work
What happens when you try to use the threader? Does it miss the needle eye, does it not grab the thread, what?
Mar 20, 2017 | Brother Sewing Machines
HOW TO ADJUST my needle threader on my Pfaff Creative Visions 5.5 sewing machine
If the tiny hook on the needle threader misses the eye of the needle, it needs a careful adjustment to align it. I do mine by using a magnifying lamp to aid viewing the mechanism, then holding the needle threader down level with the eye, gently manipulate the hook until it is able to move into the eye., usually a tiny amount either side. If it needs adjustment vertically, then it needs the small screw carefully undoing a little, until the threader can be moved slightly up, or down.
Mar 19, 2017 | PfaFF Sewing Machines
I have a Babylock BMP9 6 needle embroidery machine. The automatic needle threader mechanism is not dropping down far enough to use to thread the needles. Any suggestions on how to fix this?
On older machines that do not have the automatic needle-up feature, the user needs to manually adjust the needle height so the threader will match the needle eye.
Oct 29, 2016 | Sewing Machines
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
Needle threader not threading
1. LOOK TO SEE IF YOU HAVE THE WIRE HOOK ON THE THREADER. THIS IS A VERY SMALL WIRE THAT GOES THROUGH THE EYE OF A NEEDLE. 2. IF IT IS MISSING THEN UNSNAP THE OLD ONE AND REPLACE IT. 3. CHECK TO ENSURE THE NEEDLE IS AT IT'S HIGHEST POINT. 4. LOOK CAREFULLY TO SEE WHERE THE WIRE HOOK IS GOING TO (TOO HIGH OR LOW). 5. ADJUST THE THREADER UP OR DOWN TO CAUSE THE WIRE THREADER TO GO THROUGH THE NEEDLE EYE. ADJUSTING IS DIFFERENT FOR EACH MACHINE BUT YOUR USER'S MANUAL SHOULD HAVE THIS. ALSO, YOU CAN USUALLY FIND THIS ON YOU TUBE.
Jan 31, 2015 | Sewing Machines
How do i adjust the needle threader on a Phaff 1222E?
Bend by eye with tiny screwdriver...or replace, they do get bent
Feb 27, 2014 | Sewing Machines
Needle threader doesnt work
it would probably be better to take the machine to a sewing machine
shop & have it done.
my needle threader is attached to the needle threader bar inside the machine & I imagine your is too.
Apr 26, 2012 | Sewing Machines
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Brother Entrepreneur Pr 650 Embroidery Machine With Hoops & Frames Logo
191 people viewed this question
Top Brother Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Marion Ravendel
Marion Ravendel
Level 1 Expert
Are you a Brother Craft and Hobby Expert? Answer questions, earn points and help others
