Question about U-Line U Line Outdoor Series CLR2160SOD 15" Outdoor Clear Ice Maker with 30 lbs. of Ice Storage, 60 lbs. Daily Ice Production, Touch Glass Control, Self-Cleaning and Frost-Free Defrost
I have CLR 2060 I need the level the water on the pump
Too mush water
    Top Expert:
  • 3,698 Answers
Www.u-line.com
Posted on Jul 14, 2014
I am trying to remove the drain filter but it is stuck.
Somthing like a long nail is jamming it
You will need to remove the pump and disassemble it
Sep 30, 2014 | Bosch Axxis WFL 2060 Front Load Washer
X5 H2O Steam Mop dripping water from small hole at bottom and not producing much steam
john, I would try cleaning the mechanism with vinegar or CLR to dissolve any buildups you can't see. Rinse, fill up with fresh water and powerup. good luck
Mar 13, 2014 | As Seen On TV H2o Mop X5 5-In-1 Steam...
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Italia wont pump water for the shot.
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
this link has alot of troubleshooting ideas, and at the bottom of the page u can download the manual
Feb 26, 2009 | Starbucks Saeco Italia Digital Barista...
Bosch WFL 2060 Washer pump issue
If the pump is working then you will not need a new board..
Remove the pump from the m/c, connect live and neutral supply to the pump, it should run.
If it does then your problem could be an internal blockage in the m/c.
Hope this helps
Dec 02, 2008 | Bosch Axxis WFL 2060 Front Load Washer
CLR 2060 Clear Ice Maker
just a guess but did you make sure that the fan under the unit is turning? if you don't get rid of the heat at the condensor the freeze tray can't get cold.
Aug 02, 2008 | U-Line Icemaker
U-Line U Line Outdoor Series CLR2160SOD 15" Outdoor Clear Ice Maker with 30 lbs. of Ice Storage, 60 lbs. Daily Ice Production, Touch Glass Control, Self-Cleaning and Frost-Free Defrost Logo
281 people viewed this question
Top U-Line Plumbing Experts
Donni Steen
Tom Chichester
Are you an U-Line Plumbing Expert? Answer questions, earn points and help others
