SOURCE: samsung washing machine smells
the LE error code is an over suds error.
the smell could be coming from lint and foreign object matter collected in the rubber bellows that is conected to the drain pump this should be cleaned out i hope this helps
SOURCE: The smell that comes from this machine is
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hope your filter is clean. Don’t wait for the machine to jam to
look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such
things can be stuck around the inside tub of your washer. Try this product, it
works great on all front loaders. Use very hot water with the Affresh pellet
with no clothes and run the machine through a cycle. Also helps with any
stagnant water smells. Put the Affresh
pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help,
can't you. Thanks.
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
SOURCE: My front loading Samsung washing
run the unit with no clothes in once it has stopped check the water level. in the rear of the tub the water hould be 3 1/2 inches deep and 14 inches wide.and will taper off towards the front of the drum.
SOURCE: my samsung hl56a650 tv power cycled and then
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
