Question about Apple Macbook Core2duo 2.13ghz 2gb Ram 160gb Hd 13" Mc240ll/a
Error code mac
When i run Apple Hardware Test, I get error code "4M0T/1/40000003: Exhaust-6682
  • Apple Master
  • 3,320 Answers
HD fan is failing. Replace the fan.
Posted on Apr 22, 2014
Error code 4b1104
google the error code.
Feb 01, 2014 | Apple 24" iMac Desktop
IMac crash
Nearest I have to that is 4MOT/1/40000002:HDD. Hard drive fan. Check it is properly plugged in and it should be turning at 1000rpm at all times or 3000rpm if the drive is detected as too hot.
Jul 28, 2013 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
What does this error code mean...4SNS/1/C0000008 TL0P==124
It's a temperature sensor error, usually the fans run at maximum rpm when this happens. The error indicates the LCD temp sensor is either reporting out of range data, is disconnected, or has failed. It is probably a damaged or disconnected sensor cable. A disconnected or missing sensor would simply force the fan(s) to run fast to protect the system.
Oct 27, 2012 | Apple 21.5" iMac Desktop
Error
That error code means your HDD is dead..
It may be corrupt; it's unusable.
You will need a new SATA HDD.
Source: Google and my experience with that error in my Macbook Pro. var fctb_tool=null; function FCTB_Init_c051884345bf42a4a9c154223e7d2f63(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c051884345bf42a4a9c154223e7d2f63(document['FCTB_Init_6e224391880b406abfb85fe687432776']); delete document['FCTB_Init_6e224391880b406abfb85fe687432776']
Jul 06, 2010 | Apple MacBook Air
My macbook air hardware test shows error code 4HDD/11/40000004: internal. What does that mean and how do i resolve the problem?
The meaning of Apple Hardware Test results is Apple proprietary.
That having been said, it appears that AHT is reporting a problem with a hardware component associated with your hard drive (the drive itself, a drive temperature sensor, or something else). An Apple Authorized Service Facility will be able to give you more information.
Jul 06, 2010 | Apple MacBook Air Mac Notebook
Wont read/write hard drive
use Apple Hardware Test to diagnose the error::
1 Disconnect all external devices from your computer except the power adapter.
If you have an Ethernet cable connected, disconnect it.
2 Insert the Mac OS X Install Disc 1 that came with your computer.
3 Restart your computer and hold down the Option key as it starts up. A list of available
startup volumes appears. Click Apple Hardware Test and click the right arrow.
4 When the Apple Hardware Test main screen appears after about 45 seconds, follow the
onscreen instructions.
5 If Apple Hardware Test detects a problem, it displays an error code. Make a note of the
error code before pursuing support options. If Apple Hardware Test does not detect a
hardware failure, the problem may be software related.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 18, 2009 | Apple PowerBook G4 Mac Notebook
Screen gets distorted
Mine is doing something very similar now.  I managed to do the Apple Hardware test and it came up with the Error Code 2 FAN/5/7:  Hard Drive.  This leads me to believe that the problem is the fan by the hard drive.  Your problem may be the same thing.  If so, it's just a matter of finding the part and the installation instructions (on the Apple web site).
Try the Apple Hardware Test from the Mac Os Software that came with the computer.  You install Disc 3 and shut down the computer.  Then turn it on and right away press C on your computer. This action will take you to the Hardware test.  Press one of the buttons that does the test and see what results you get.
If you get the same error code you might want to check out welovemacs.com for the fan.
May 11, 2008 | Apple iMac G5 Desktop
DVD write problem and hardware test error code
I hope this works for you it did for me when I updated all my firmware.
http://docs.info.apple.com/article.html?artnum=88275
Jan 13, 2008 | Apple Power Mac G5 Desktop
Error code when running Apple Hardware Test
Its an issue with the hard drive in the lower slot. The volume may be corrupt of the drive could be physically damaged. Did you install the bottom drive? is it the drive with the OS installed?
What does SMART statues report in DISK UTILITY?
Hard Drive/Application/Utilities/Disk Utility3a047e2.png
Let me know.
Oct 27, 2007 | Apple Power Mac G5 Desktop
Apple Macbook Core2duo 2.13ghz 2gb Ram 160gb Hd 13" Mc240ll/a Logo
210 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
