Question about GE 168997 Deep Fryer
I need lid screws for 169219
I need screws for lid and filters in lid
Water is leaking from filter control valve when system on and it sounds like seal may have been broken? Where should I look to fix.?
That sounds like the multiport. You need to make sure all the gaskets inside are in good shape and that all the screws holding the multiport together are tight. First start by taking the lid and handle off of the multiport, there is a lid gasket that may be in bad shape. If the gasket leaves black on your fingers, then that says the gasket is bad. Replace it and tighten the lid back down with the screws and bolts.
Jan 12, 2017 | Hayward SAND FILTER, PRO SERIES
Changing hepa filter
Helen,
Remove the lid of the Dust Bin, and while holding it upside down in your hand, insert a philips screwdriver (this needs to be a medium screwdriver but with a long blade!) down through the centre of the actuating column. Hold the Filter Refresher knob (green) to prevent it from moving and undo the philips screw.The assembly will now come apart. Pull the actuating column out (the philips screw will remain in the column so don't loose it) The Filter Refresher knob will come away from the Lid. The Hepa Filter can now be removed and the replacement fitted. If the replacement filter is not supplied with a rubber gaskit use the gaskit from the old one..Re-assemble in reverse order.
Jan 11, 2014 | Panasonic Mc-Ul594 Eco Max - Bagless...
Getting mist thru exhaust...according to your website i need to take out the filter...how do i do that?...i have craftsman model wetvac that doubles as a bllower..thanks
Pull the blower out from the lid. flip it over and your should see 3 or 4 screws that hold the filter cover on. remove those screws, remove the filter cover, then remove the filter. It is a dirty job. Most often the filter can be beaten clean. Some are washable. Clean or replace then reinstall. Good luck!
Jun 10, 2011 | Craftsman 17765 Canister Wet/Dry Vacuum
Hello I need to get to the belt on my dryer how do i get to it?
Unplug the dryer.
Remove the 2 screws under the lint filter lid.
Remove the lint filter.
Use a putty knife to push in on the 2 clips on the right and left front between the lid and the front panel.
Raise the top lid and move it to the back of the dryer.
Look inside the right and front corners and remove the 2 screws holding the cabinet case to the front panel.
Remove the wires from the door switch.
Pull up and out on the front panel.
You are now in the dryer.
May 24, 2010 | Maytag MED5700TQ Electric Dryer
Dyson DC07 main filter can it be removed to clean?
Yes, remove the dust bin and set it aside. Using a small screw driver gently pry on the lid that the dust bin sits on. you'll see little holes to insert a screw driver and pry back on the lid. Start on one side and pry at the three points to insert a screw driver and then remove the lid and replace the HEPA filter with a new one from EBay, local vacuum store, Dyson direct, etc. That filter is not washable.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a 1989 buick park avenue electra and I don't know how to remove the air filter box lid in order to change the air filter. I see no spring clips that are holding it into place.
I had a 1989 Buick Regal, and from what i remember, there were philips head screws, or bolts in the corners of the lid, that when unscrewed, they separated the top from the bottom, thus exposing the filter. And I believe they screw/bolt heads stayed connected to the top lid part.
Totally going on memory here. Hope this helps.
Apr 06, 2010 | 1989 Buick Electra
How do you replace a belt on model 11060622990
Unplug the dryer.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
Door switch broken , need disassembly instructions. manual?
take the lint screen off remove 2 screws. lift the lid by pulling one side toward you and up and then do the other side you will be able to see the lid switch this only works on the ones with the lint filter on top of the lid. if you dont have that kind let me know.
Jun 05, 2009 | Kenmore Dryers
Noise from the lint vent
idf top mount filter remove screws under filter lid remove nback cover remove 4 screws holding cover and lint housing to back pull housing down and out ..something may be hitting wheel just clean and reassemble ..on inside door filter remove bottom cove remove filter remove screws holding filter/blower cover in place ckd for smae objects clean and reassemble
Sep 02, 2008 | Kenmore 63012 Electric Dryer
GE 168997 Deep Fryer Logo
55 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
