Question about The Times Case Corporation Tractors International Harvestor
480 D TRACTOR WON'T START AFTER I CHANGED THE FILTER !
HOW DO I REMOVE THE AIR LOCK FROM THE FUELING SYSTEM ?
    Problem Solver:
  • 7 Answers
Did you prime I
Posted on Apr 18, 2014
Stiga park lawnmower
Are you certain it is a fuel problem and not electrical? Remove fuel line right before it enters carburetor, turn mower over and see if fuel is pumping out. If not, check for any foreign material in fuel tank where fuel exits the tank to the fuel line. You can do this by blowing pressured air into fuel tank and observe if fuel is coming out of end of fuel line. Check for clogged fuel filter.
Jun 08, 2013 | Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 02 cr80 just shut off while I was riding and it won't start I change the plug ...what else can it be??
Sorry for this simplistic message, but:
Is there enough fuel? Check and refuel if need be.
Is the fuel switch in the open position to feed fuel to the carburetor?
Has the air filter choked up - blow out, clean etc;
Are all the safety interlocks closed/open to allow restart?
Is the park brake locked into position to allow restart?
Sep 21, 2012 | Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
My L120 starts and runs for about 15 minutes then starts to back fire,loses power,and then seems to stop getting gas then stalls.I take the gas line going to the fuel filter off,letting air back into the...
You may be getting a partial vacuum lock in the fuel feed if the tank is NOT venting correctly. Your statement indicates the possibility. Many tanks vent (atmospheric pressure out and in) by the thread pattern on the fuel cap. May I suggest leaving the cap a little loose and adding some fuel system cleaner to your fuel supply. I recommend Chem Tool's Berryman B-12 (at auto parts stores). The rate is 1 ounce/gallon for cars. A little stronger dose won't hurt the carburetor. If this doesn't help, it may need to be removed and cleaned as sediment, fuel line debris and water may be in the fuel bowl (you can remove the bowl and clean it). Debris even just in the bowl will certainly cause runnability problem like yours. Try the above remedies and post back!
Aug 12, 2011 | John Deere Garden
Skid steerer won 't start
You need to remove the fuel filters and fill them with fuel, and them if you engine is equipped with a primer,,,,prime the fuel system.
Simply filling the fuel after a run out will never start it. The system has air in it that needs to be primed out.
Aug 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Diesel tractor ran out of fuel now it won't start
Agree with with previous answer.
Check your fuel filter & make sure it's full of fuel,
usually the problem if the motor wont start after
running it out of fuel.
Feb 01, 2010 | The Times Case Corporation Tractors...
I get a vacum lock on the fuel
sounds like you need a new fuel cap as its pulling a vacuum on the tank and not letting fuel flow! also double check thats theres no debris in the tank to stop up the outlet
May 04, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
The Times Case Corporation Tractors International Harvestor Logo
42 people viewed this question
Top The Times Toys Experts
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
