Question about Napoleon Grilling
Naploleon Ledgend rear burner wont start
I just purchased a Legend model, all burners will start except the rear burner. You can smell gas but wont fire. Is there an adjustment?
  • 131 Answers
SOURCE: burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Posted on Mar 10, 2008
  • 338 Answers
SOURCE: gas burner not igniting on Hotpoint RGB745, can smell gas
check to see if any of the port holes are clogged.. usually where the ignitor comes into the burner head
Posted on Jan 20, 2009
gcken
  • 140 Answers
SOURCE: Weber - Igniting the three grill burners (front, middle, rear)
it need a clean
Posted on Apr 28, 2009
  • 10865 Answers
SOURCE: the entire 4 gas burners do not get hot
here is the link to brinkmann.net so you can contact them directly.
http://www.brinkmann.net/Customer%20Service/
Now, the most common problem on all recent gas grills is that the regulator in the gas hose now has a safety feature which prevents it from leaking. Sometimes this feature gets stuck.
Unscrew your propane tank from the regulator, tap the regulator a couple of times and reattach it. This may solve your problem. If not, use the link above.
Posted on May 29, 2009
SOURCE: 1st burner goes out when 2nd burner is turned on
I had the same problem. They original regulator and hose were poorly designed for this model. There isn't enough room underneath without crimping the hose. I bought a standard regulator and shorter hose combination a Home Depot for about $20. It makes a 90 degree turn coming out of the tank and does not kink the hose.
It was worth the $20.
Posted on Jun 03, 2009
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
I just purchase this grill and was testing all burners .. all of them except the one going to the smoker worked fine .. tried to start it manually but it wont start this way either ... I am assuming that...
Yes, it is a Brinkman's problem. But, Home Depot will generally exchange it for a new one.
But, first, check the gas line running to the smoker burner. Does it appear to crimped or bent in any way? If this is the case, it won't allow gas to the burner. This may have occurred during shipping or it's a manufacturer's defect.
Also, try pushing in on the burner control knob when you manually try to light the burner. Since it's a low output burner for smoking, it may operate differently than the other main grill burners.
Hope this heads you in the right direction in resolving your burner problem.
Feb 24, 2011 | Brinkmann 5 Burner with Smoker 8101750S
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Model 790, propane, right rear will not light, piezo sparker works, seems like no gas to that one burner- ( the simmer )
i have a kenmore gas range when i turn front and rear burner no light but i can hear the sparker and smells the gas. any suggestions?
Jan 21, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Gas burner not igniting on Hotpoint RGB745, can smell gas
Jan 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Grilling Logo
29 people viewed this question
Top Napoleon Grilling Experts
Paul Carew
Lawrence Oravetz
Pierre Legault
Are you a Napoleon Grilling Expert? Answer questions, earn points and help others
