Question about Singer Sewing Machines
May 145H654 just turned off and will not sew
My145H654 machine just turned off while I sewing and will not start again
  • Singer Master
  • 7,365 Answers
Make sure the outlet has power, also could be the motor, make sure the power cord is inserted snuggly into the plug on serger . if the serger still won't come on , then the machine needs to be checked
Posted on May 07, 2014
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
  • 240 Answers
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Posted on Jun 11, 2009
  • 10 Answers
SOURCE: Husqvarna Sewing Machine starts sewing when power switched on
The problem is probably the foot control. The little wires wrapped around the insulator have broken and are shorting against each other or the cord itself has a short. You can purchase an aftermarket foot control at your local shop, this is the cheapest way to try first, if that does not correct the problem replace the cord.
Posted on Jun 30, 2009
How do i get sewing machine to stop showing code 6 when I have done everything by the book. sews perfect stitches for about an inch then code 6 and locks again?.
Since it is a computer,maybe try unplugging for about a minute and plug back in and turn the machine on. See if the code is cleared. hope this helps
Oct 02, 2014 | Brother Sewing Machines
I have an older Brothers Sewing machine, to thread the bobbin you need to turn the handle to open I up. After doing this you need to tighten it back up so you can sew again. This is where I am havin
It seems that your explanation has bee truncated.
Link below is to videos on youtube regarding winding bobbins on brother sewing machines. If you don't find an answer there please re submit your problem.
Brothers Sewing machine wind bobbin YouTube
Sep 15, 2014 | Brother Sewing Machines
Problems with foot pedal light
sounds like there is a design fault, I suggest if you can take the
machine back and get a different brand of sewing machine.
I've been sewing for over 25 years and I would put up
with that kind of sewing machine.
probably a computer problem.
Nov 15, 2012 | Sewing Machines
I pushed the button that has a dot with a circle around it, instead of the ^ down button and now my machine wont sew. I have unplugged it and it still just beeps and wont sew.
The machine is sewing a locking stitch. Just let it keep "sewing" in the same spot - then press the presser foot again and it will start sewing again. Hope this helps.
Aug 20, 2011 | Janome Memory Craft 4000 Sewing Machine
Sewing Machine light flickers/dims while sewing.
There may be a loose connection. If this is a brand new machine the warranty should cover the repair.
Check the return policy at Sears/K-Mart as it may be better to return it for a replacement.
Feb 20, 2010 | Kenmore Sewing Machines
Will not sew
Try turning off the machine and turning it on again. Sometimes this will reset it so it will work. Also, make sure the embroidery foot is in the down position; the machine will pause and "beep" if you haven't lowered it. Hope this helps!
Nov 10, 2006 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
