Question about Tripp Lite Computers & Internet
I have a Tripp-Lite 1000 Lcd, surge protector, that keeps my TV and Stero on ofter you lose power. The unit wasn't working. I tried to push the power button, and there is no power to the plugs
  • 21 Answers
Probably the battery is bad, you will need to replace it.
Posted on May 08, 2014
4 Suggested Answers
  • 105 Answers
SOURCE: Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Posted on Jul 26, 2010
  • 3 Answers
SOURCE: Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Posted on Oct 19, 2010
SOURCE: The LCD display no longer works on my Tripp Lite
Be aware.
My Tripp LIte Omni 1000 LCD almost caught on fire.
I had been experiencing a spike in my power bill to the tune of 1000 Watts an hour for everything running - 24x7. I started the survey of all my equipment; TV 162 Watts; Fridge 228, etc. but none of these devices are on all day and night. I finally mapped out all the outlets and lights and was about to begin the survey. Other than the flickering lights, one big clue was that my TL's lcd was displaying a spike in voltage DOWN to 95 or so, the relay would click, etc.
I decided to begin my survey and use my second TL to help me see which circuit was faulty. When I looked at the LCD, it was blank. I pushed the ON button and all the devices plugged in went OFF and then I saw smoke coming out of the back. I quickly unplugged everything and then watched my meter. When this UPS was plugged in, there was about 1000W used per hour; I monitored it for 10 hours; 400W were used (total).
So... not only was it a fire hazard, but it sucked up 900W or so an hour.
Posted on Jun 02, 2011
Why is my tripp lite 500 only working on one side?
Go to Tripp Lite web site to troubleshoot the problem. Surge suppressor might have blown.
Jul 25, 2014 | Tripp Lite Computers & Internet
I have a Tripp-Lite 1000 Lcdf, surge protector, that keeps my TV and Stero on ofter you lose power. The unit wasn't working. I tried to push the power button, and there is no power to the plugs
Hi Richard,
Sounds like the you will need to replace the battery in the UPS. When the batteries are completely depleted the UPS will not turn on.
If you need UPS, Surge, or Power Related help contact:
Inside Service Sales
Daniel Salazar 800.260.2259 daniel@psihq.com
Power & Systems Innovations, Inc.
customerservice@psihq.com
Power & Systems Innovations, Inc. is an Elite Certified Service
Sales Partner for APC/MGE brands manufactured by Schneider Electric
Visit us at www.psihq.com
Apr 18, 2014 | Tripp Lite Computers & Internet
Tripp.lite ups fault displayed and beeping
My Tripp Lite was showing a fault this morning for no logical reason, ran this self test as suggested and all cleared. Thanks.
Apr 24, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
I need a manual for Tripp lite omniplus 1000 lcd
Changing the battery
If your Tripp LIte Omni 1000 LCD display a fault icon and beeps after changing the battery, try the advice given by the buzzerman which worked perfect in this case:
1. Turn the UPS on. Press and hold the ON/OFF button for one second.
2. Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until beeps several times). The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound. At the end of this process the fault icon and the beeping turned off.
Feb 15, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
I have a omni 1000 lcd. power went off when it came on the thing won't work. When I bypass the unit and plug my TV into the power out let the TV works . Have any idea what could be going on ,is the...
The UPS is either off, has a dead battery or is dead. Does the UPS power anything at the surge only outlets? If it doesn't, it's off or dead. Turn it on and check again.
The Omni 100 VS does not have a user-replaceable battery or other parts. If the battery or UPS is dead, replace it.
I hope this helps.
(when the UPS is off but connected to power, the battery should charge.)
Jun 28, 2011 | Tripp Lite (OMNI1000LCD) UPS System
The LCD display no longer works on my Tripp Lite Omni 1000 LCD. Also, half of the power outlets on the back of the unit no longer work.
Be aware.
Nov 28, 2010 | Tripp Lite (OMNI1000LCD) UPS System
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
I bought a TrippLite Internet Office UPS surge protector in January 2009. I have misplaced the manual. Recently it began to beep for no reason. There is no power failure. It was so annoying I had to unplug...
this unit come with 4 with battery backup of 12v 7ah. check what are the indicator display shown?
it very diffcult know what the problem if u can give more info. u can try to replace the battery with new batts.. and test the ups if it not beeping again it show the battery problem. or maybe you had plug in more the the power consumtion that why it keep sound the alarm indication overload try to serperate the load. if u wan a user manual go to this website to download the manual: http://es.tripplite.com/support/manuals/index.cfm
u will get will u wan...
Apr 12, 2009 | Tripp Lite Tripp-Lite Internet550U 550VA...
Computers & Internet Logo
302 people viewed this question
Top Tripp Lite Computers & Internet Experts
 Kevin Kershner
Kevin Kershner
Joseph Hoffmann
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
