Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Battery indicator flashes,
After several minutes or taking 5 pictures, battery indicator starts flashing, a fully charged battery was placed, i have 2 batterys of the same kind and both give the same problem, what can i do about this. Batterys are about 6 months old , but problem started from using them new. what can i do about this.
  • 1,162 Answers
t00nz
  • 4738 Answers
SOURCE: Canon A540 flash charge not holding
Some of The Canon Powershot A530 and A540 cameras are subject to a advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Dec 16, 2007
t00nz
  • 4738 Answers
SOURCE: Problems with the battery and the flash on my canon powershot A530
Know this is an old post but... Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mentioned that your batteries weren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
Posted on May 28, 2008
  • 14 Answers
SOURCE: Canon A720IS flash problem/low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Lift masters battery keeps bleeping every 5 seconds,does this means my battery needs replacing.
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Kodak EasyShare C643 Digital Camera won't take picture
take your battery out for 5 mts then try it again
"Was this helpful?"
Apr 02, 2009 | Kodak EasyShare C643 Digital Camera
Auto flash not working right
This is actually a repair issue with the flash charging indicator switch. It needs to be replaced as it has failed. You can call Olympus Customer Service to discuss their repair policy and preocedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Feb 17, 2009 | Olympus Camedia Stylus 300 Digital Camera
Sony Cyber-Shot DSC-F707 ...No flash.
Same problem for me. The flash won't pop-up anymore, even when I select the forced flash.
Jan 12, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Kyocera Finecam S5R digital "flash close"
You forgot to open the shooting flash on the top of camera
Nov 24, 2007 | Kyocera Finecam S5R Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
