Question about Indesit DF125 24 in. Built-in Dishwasher
Power on but mechine not start
Inlet not on not working any function
  • Indesit Master
  • 3,247 Answers
If you are able to select the program but start button is not responding, then the door latch switch is not detecting closure of the dishwasher. Need to check this out.
http://www.indesit.co.uk/_pdf/booklets/02/45/19507195700_UK-USA-AUS.pdf
If the situation detailed on page 12 is not helping then see this diagram.http://www.espares.co.uk/product/es836224/dishwasher-door-lock?ModelId=1124397
Posted on Apr 19, 2014
How to Hard Reset Canon iR6000
press aditional function ,then 17+39 ( 1and 7 same time , 3 and 9 same time) again additional function .and select 95 th option in display (e355 and all ram clear ) press 2 and enter ..within few minitus mechine restart if restartting time just swich of mechine manually and on
Dec 14, 2013 | Canon imageRUNNER 6000 Copier
Begins to fill for wash and then stops and starts a low picthed hum/vibration
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Possible that the HUM is due to inlet valve humming
Jan 16, 2013 | Maytag Centennial MTW5800TW Top Load...
Ir1024 given error 000
turn onn the mechine press star button of additional function and press 2 then 8 for same time then press star select copier option then function then clear then err then ok restart the mechine it will work
hope soloution help you
Sep 05, 2012 | Canon Office Equipment & Supplies
Canon ir1024 given error 000
No water coming into our westin 733
When the function is chosen and the washer is started , the inlet valve must work and allow the water to flow into the washer. If there is no power then the program controller is faulty. If there is power then the inlet valve must be checked, it can be clogged at the inlet filter or if there is low flow at the inlet.
Jun 25, 2011 | Westinghouse Dishwashers
Power washer will run fine for about 30 to 40 minutes then stalls, I wait a few minutes and starts but it runs rough and stops.
Sounds like a fuel problem eighter a filter or you have debrie in your fuel tank thats cloging the inlet from the tank to the carburtator . Its that or a problem with the water pump . That could also be clogging and putting exesive back prressure on the engine shaft causeing stalling . What dose your water flow look like do you loose that first before the engine starts to bog down or dose the engine go first and the pressure follow . Also do you winterize the mechine i owen and repair many washers if you need more info you need to give more pier_j
Feb 20, 2011 | Dewalt DPH3100 Gas Pressure Washer
The cooling function is always on. The dryer will not heat regardless of the mode that it is in Normal/Timed/Manual
hi your mechine will be having a option called reset button by reseting it your mechine program ill be reset and come s to normal state
Aug 24, 2009 | LG Dryers
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
LG WM-2277HW Front Load Washer E1 error
You may have a bad valve. The multi valve is cold and the single is hot. You can go into test mode and check them out to see if how the are fuctioning. Caution must be used. DO NOT GO INTO TO TEST MODE WITH CLOTHES IN UNIT AS IT WILL NOT BALANCE OUT FIRST AND WILL BOUNCE ALL OVER, AGAIN DO NOT DO THIS.
here is how to acces the test mode
With the unit off
Press and hold 'spin speed' and 'soil level'
turn the power on
press the start button to advance
once the tub will rotate clockwise
2nd time low spin speed
3rd high spin
4th inlet valve prewash
5th inlet main wash
6th hot water
7th bleach
8th tumble counter clockwise
9 heater comes on for 3 seconds
10 circulation pump
11 drain
12 power off
again do not attempt this with clothes in the unit.
if the valves don't activate fully than it is a bad valve and it has to be replaced.
Sgt 48
May 26, 2008 | LG WM-2277HW Front Load Washer
Washing machine doesnt work
Have u checked for power right at the end where it hooks to the mechine... to make sure you have power there? also check door switch
Sep 02, 2007 | Hotpoint Aquarius WD63 Front Load...
Indesit DF125 24 in. Built-in Dishwasher Logo
73 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
