Reset sherwood amp
How do I connect a pair of speakers to my sherwood amp
  • 66 Answers
From the rear. if you have analog passive speakers use the black and red connector. if digital active speakers use the rca jack holes
Posted on Apr 19, 2014
  • jeff knowles Apr 19, 2014
    from the rear. if you have analog passive speakers use the black and red connector. if digital active speakers use the rca jack holes. then go to setup speakers menu and do the sound test.it should pick up the new connection
5 Suggested Answers
Grubhead
  • 5487 Answers
SOURCE: sherwood r525 repair
You need to look at the devices on the heat sink. They will probably need replacing. You can check (if they are transistors) with an ohm meter if they are working. Connecting it accross the terminals of each device will probably show a short circuit. Just like if you had touched the probes together. If so there will be some blown fuses somewhere.
Posted on Feb 25, 2013
dunnbiker
  • 8546 Answers
SOURCE: Hello, I have a Sherwood RX-5502
The statement on page 7 might allow enough wiggle room for a single pair of 4-ohm speakers used alone. Procede with caution and don't try to blow the walls down with them. Monitor for excessive heat or strain and if it clips or self-protects back off.
http://www.sherwoodusa.com/pdf/RX-5502(A).pdf
Posted on May 30, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a sherwood RX
By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
Posted on Mar 25, 2011
kywriter
  • 25 Answers
SOURCE: Can I connect my TV through my Sherwood amp ax4050r so that I can use the HI fi speakers for TV as well?
Easiest way is to use the Audio Out RCA plug to the amp, probably at line in.
If no RCA plugs on the TV, you'd have to alligator clamp onto one of the speakers.
Posted on Aug 19, 2012
How do I connect my RX-4109 to a Crown power Amp?
If your Sherwood has preamp outputs, you can connect directly to the power amp inputs.
Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
Manually reset convertible top
basically the unit is recognizing the analog signal but not the digital signal.. may need a converter..
Jan 20, 2014 | Sherwood Audio Players & Recorders
Hello, I have a Sherwood RX-5502 and currently have a pair of 8Ohm speakers hooked up to the SPEAKER A terminals. Can I hook up a pair of 4Ohm speakers to the SPEAKER B terminals without issue from...
May 30, 2011 | Sherwood RX-5502 Receiver
I have a sherwood RX 4109.....can i hook a pair of 6 ohm speakers and then a powered sub?
Mar 25, 2011 | Sherwood RX-4109
SHERWOOD RECEIVER 6108. I don't have the remote. Are some funtions only available by using the remote? When I plug it in I have standby mode but no florescent display, when I press the audio button on...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 23, 2011 | Sherwood RD-6108 Receiver
Is there a way of connecting my ipod to my sherwood cd player?
The answer isn't with the CD player, it's with the amp.
Does the amp have selectable inputs, or does it just have one input for each channel?
If it's a simple power amp, then you'll have to unplug the CD player and connect your iPod to the amp inputs. I'm guessing that the CD player connects to the amp with RCA (phono) connectors like these ones.
If that's the case, you can get a cable (like this one at Radio Shack, but any office supply store will have one too) to connect your iPod to the amp.
Jul 31, 2009 | Sherwood CDC-5090R 5-Disc CD Changer
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Insignia NS-R2000 receiver
Check the impedance ratings of your speakers. Sherwood, the actual manufacturer of the NS-R2000 receiver, suggests that you use speakers with an eight ohm impedance if you have only one pair attached. If you have two pairs of speakers attached, the impedance rating of each pair should be sixteen ohms.
This is because Sherwood wired the receiver such that an additional pair of speakers is placed in a parallel circuit to the first set. When this is done, the impedance (resistance) of the load seen by the amplifier drops. As resistance drops, you get closer to a short circuit (no appreciable resistance).
Many other receivers wire the speakers in series, which causes the impedance to go up.
Personal experience seems to suggest that the amplifier is OK with a four ohm load on it. It does run warmer with a four ohm load, which is what you'd expect. It's when you have multiple sets of four ohm rated speakers that you will get into trouble, as this means the receiver only sees a two ohm load. This will cause overheating and shutdown.
At this point the power transistors in the amplifier may have been damaged. It may require repair. Fortunately, replacement parts are readily available (though not from Sherwood or Insignia). If it continues to shut down, stop using it. You could end up burning out your speakers.
Jan 09, 2008 | Yamaha RX-V2400 Receiver
Home Entertainment
It depends on what you want. Is your existing solution a surround sound system (You only mention a subwoofer, what other speakers do you have?)? Do you want full 5.1 or 7.1 surround sound? If you don't have this, and want it, your amp will have to be replaced, but your sub will fit in just fine. If you currently only have front left and right speakers, you will need to purchase a centre speaker and another pair (5.1) or two pairs (7.1) of speakers.
Sep 13, 2007 | Audio Players & Recorders
137 people viewed this question
 Grubhead
Grubhead
