Question about Bissell PowerForce Bagged Upright Vacuum, 71Y7W
Bissell powerforce with bag, not picking up, but alot of suction in hose. Brushes are rotating, just not picking up.
Model 71Y7 W
  • 4 Answers
Flip it over and unscrew the screws that hold the bottom skid to the chassis. Pull that off and check the intake to the hose. You will likely find it stopped up there.
Posted on Apr 19, 2014
reddevil6
  • 1673 Answers
SOURCE: Brush is not rotating.
Turn the vac over, remove the access plate, covering the brush roll, 2 to 4 screws. Brush roll part number is 2032032if you need it, belt is a Bissell Style 7. While you have the brush roll off, check in dirt inlet to see if it is clogged, also check the hose to see if it is clogged. You won't feel suction at the bag tube, it has to have a bag on it and the lid closed before it will create suction.
Posted on Jan 09, 2008
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
SOURCE: bad suction on bissell powerforce bagless vacuum
I took the bottom apart and it needed a new belt and that was the problem so it's fixed.
Posted on Jan 17, 2009
  • 33 Answers
SOURCE: My power brushes on my
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Posted on Jan 18, 2009
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
I have a bissell powerforce helix model 1700U.barely had it a year. Recently it stopped suctioning into the canister. I took it apart and cleaned the canister, filter and other associated parts as well a...
I would suggest taking it to your local vacuum cleaner store and have them look at it. Most bagless cleaners need to be serviced annually to maintain performance.
Jul 03, 2017 | Bissell Vacuums
Vacuum cleaner does not pick up
Hey Marie! I know how frustrating it can be when you're ready to vacuum and no suction.
Here is a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1498&cid=ccsocial
Apr 01, 2013 | Bissell 3522 PowerForce Bagged Upright...
No power on a bissell 71y7 when turned on
Hey, having no power when you want to vacuum is inconvenient.
You may want to try another outlet and look for damage on the power cord. If you are still having problems, you may want a Qualified Technician at one of our Authorized Service Centers inspect the vacuum.
Here's a quick link to locating an Authorized Service Center.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 28, 2013 | Bissell 3522 PowerForce Bagged Upright...
Keeps showing the bag is full
are you getting suction.check the hose at the end and see if there is suction.is your brush roller turning.no suction will tell it that its full please leave feedback
Mar 20, 2009 | Bissell 3522 PowerForce Bagged Upright...
Kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Jan 26, 2009 | Kenmore Vacuums
Bad suction on bissell powerforce bagless vacuum
Jan 16, 2009 | Bissell 6594 PowerForce Bagless Upright...
Dec 29, 2007 | Bissell 3522 PowerForce Bagged Upright...
My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Dec 15, 2007 | Bissell 3522 PowerForce Bagged Upright...
Bissell proheat 2x
Yes, there are belts for both sides, but if they look ok, then the brush motor may be bad. Brush motor part # 2036757 , right side belt # 2036804 left side belt # 2036688
Nov 10, 2007 | Bissell 3522 PowerForce Bagged Upright...
Bissell PowerForce Bagged Upright Vacuum, 71Y7W Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
