Question about Coby MP301 MP3 Player
Won't work at all any more either with headphones or on my computer
When I turn on mp3 player the screen lights up and says COBY and that's all it does, can"t turn on/off or use play mode. When I plug into computer an hour glass shows up and icon for the device does not show up on computer bar at all????
3 Suggested Answers
  • 52 Answers
SOURCE: how to copy data from coby mp3 player to computer
connect it to the pc and go to start menu >my computer >the name of the device then double click it [HOPE i helped][rate me]
Posted on May 16, 2009
  • 13 Answers
SOURCE: Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Posted on Apr 10, 2010
No sound
Please confirm that the volume is turned up and the headphones you're using work by using them on another device. If both those points are confirmed, you may have a faulty headphone jack. Take (or send) the unit for repairs.
Oct 05, 2014 | Coby MP305 MP3 Player
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
I can't hear on my mp3 player
Your headphones may not be working. Try using them on another device like a computer or radio. If they work there, then you could have an audio jack malfunction.
May 07, 2012 | Coby MP-610 MP3 Player
Headphone jack requires bending the headphone jack to a side to get stereo. this is the coby mp725 16 gig love the unit. got it as a gift. had to send my first unit in due to headphone jack not working....
This problem is common with a lot of MP3 players. It is caused by excessive movement of the headphone jack and causes the headphone jack has worked loose from the circuit board.
To fix this problem the MP3 player needs dismantling and the headphone jack needs resoldering onto the circuit board to get the headphone working properly.
Jun 30, 2011 | Coby MP725Digital Media Player
My Coby mp3 player won't connect to my computer
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
c. Make sure the player is TURNED OFF ! ! !
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
(Found HERE if you have had to format the player)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps
Apr 05, 2010 | Coby MP-610 MP3 Player
I transfered some songs onto the mp3 player. It froze up and won
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 01, 2010 | Coby MP-610 MP3 Player
My Coby MP705-1g MP3 player is not working
In the back of the Coby is a reset button very tiny use a pin is by the headphone icon, click and wait to reset the product, just follow any instructions at the screen.
Dec 27, 2008 | Coby MP-705 Digital Media Player
Coby MP-C848 MP3 Player
how do i get music on to my coby mp3 from the computer, my daughters works from the computer why doesnt mine
Jan 01, 2007 | Coby MPC-848 MP3 Player
Coby MP301 MP3 Player Logo
24 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
