Question about Cub Cadet Garden
How can I override the auto shut down for a cub cadet?
The override is preventing the lawn mower from starting.
  • Cub Cadet Master
  • 2,478 Answers
Yes, that safety part. In seat, clutch in, transmission in neutral, deck not ingauged
Posted on Apr 18, 2014
  • Daryl Gleaton Apr 22, 2014
    Ok, you can put a jumper wire between the two wires going to the seat switch. That will eliminate the switch, then see if it cranks and runs. If it does then replace the switch.
  • Dennis Key
    Dennis Key Apr 23, 2014
    Yes, but be careful till you can a part.
  • 742 Answers
There is a switch under the seat that has to make contact for the mower to start. I would not advise bypassing it though. A little WD-40 on the switch while working it uo and down will usually clean up the corrosion and get the switch working. If not then replace the switch. It should only cost five or six dollars.
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 176 Answers
SOURCE: looking for a diagram for
TRY CONTACTING CUB CADET MANUFACTURER
Posted on Aug 29, 2011
  • 122 Answers
SOURCE: I need to replace the
Here's a good visual diagram but looks like there is part number variations according to the serial number on your spindle assembly. Hope this helps.
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1050+Tractor+%282007+%26+before%29&dn=0125700050
Posted on Aug 30, 2011
BAMOUT
  • 2478 Answers
SOURCE: need wiring diagram for cub cadet lawn mower lt1045
Posted on Mar 15, 2012
  • 6468 Answers
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
Posted on May 14, 2012
How to override the seat safety switch on a cub cadet xt2 riding lawn mower?
My safety switch on my MTD was just a plug in. I pulled the plug out of the switch and it works ok now with out the switch. Just remember it is for your safety but mine when I leaned over under a low tree the engine would shut off. So I disconnected it.
Sep 02, 2017 | Cub Cadet Garden
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet zforce 48 zero turn. It starts right up, but when I take the brake off it shuts off.
Can't get my Cub Cadet started. We've replaced the battery, checked the seat sensor all is good. Any advise would be appreciated!!
Thanks
Angie
Apr 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
224 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
