Question about Pentair Mastertemp Heater
Pentair mastertemp 200 cycles on and off within 1 degree of set point
Heater reaches within 1 degree of desired temp then cycles on and off every 20 seconds. I have changed thermistor and thermal regulator. Do I need a new control board?
  • William Kerry
    William Kerry Apr 19, 2014
    I also replaced the temp high limit switch. It doesn't matter if I set the water temp to 95 or 102 or anything else. The cycle problem begins within 1 degree of the selected temp. It's as if the system is too sensitive to temperature fluxuations.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Try calibration that might take care of problem otherwise sounds like new board
Posted on Jun 10, 2014
rcampsr
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
Posted on Aug 30, 2009
adamh294
  • 310 Answers
SOURCE: Pentair MasterTemp 400 Heater Will run fine for
This reminds me of some of the High temp sensors ive replaced. I would start with checking the pumps flow to the heater. Make sure there are no abstructions and at least 35 GPM (gallons per minute) running to the heater. If your flow is too low, you will trip the high limit sensor after a short while.
This could also mean you need to clean out the heat exchanger. When an exchanger gets dirty, it blocks the flow of water, slowing it down and "super heating" itdue to the water being in contact with the exchanger for too long. This will also trip the high limit and call for service.
If both the above items check out, contact me @ adamh@newconceptchem.com and I will guide you further.
Posted on Nov 23, 2010
  • 910 Answers
SOURCE: Pentair Master Temp 400 E05
If you've already changed the thermal regulator then the only other thing it could be is the flue/flame sensor.
It could be just a loose or bad connection so I'd check them first before replacing it.
If you've got a meter then you could disconnect the sensor and check its continuity (should be 3-4M Ohms). If its OK then check the continuity of the wiring between the sensor and board.
Posted on Jun 12, 2011
SOURCE: Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Posted on Jul 23, 2011
I have a Pentair Master Temp 200. My pool tech fixed the E-05 error code a week ago. Now the amber heating led blinks for maybe 30 seconds but the heater doesn't come on and goes to the service heater...
Take off he front panel so you can see the back side of the circuit board.
Turn it on and once it fails see what red lights are lit on the back of the board, this will point you in the right direction as to what needs to be addressed.
Feb 22, 2015 | Pentair MasterTemp Pool Heater 200, 000...
MasterTemp 200 cycles every 30 seconds
since you already replaced the thermisto next would be the control board
Apr 18, 2014 | Pentair Pool & Spa
Heater will not come on.
controller temp sensor bad
Jan 06, 2013 | Pentair Mastertemp Heater
What temperature does a pentair high limit switch trip
check gas pressure if ok check burner tubes over heating
Apr 09, 2012 | Pentair Mastertemp Heater
I have a Pentair Mastertemp 400. It worked fine for 3 years until the temp sensor went out and both (internal and external) were replaced about a year ago. It then worked fine for about another 7-8...
You might have a much bigger issue than the temp sensor. When the heater is running hold the "pool" or the "spa" button for 12 seconds. This will show the exhaust temp, if the temp is rising above 375 degrees with in 1-2 mins then your not getting the heat out of the heat exchanger.
One other thing to check would be an external by-pass. If you have an external by-pass make sure the by-pass is set correctly. Opened or closed to much can cause the problem your having.
Mar 04, 2017 | Pentair MasterTemp 400000 BTU Pool and Spa...
Have a brand new Master Temp 400K Propane with an Intellitouch and the heater shuts off at 84 degrees. Do I need to set a max temperature from the heater control panel?
If this heater has pool mode and spa mode as an option, and you need the water higher than 84 degrees, you must set it to spa mode even if it is a pool. As a regulation, these heaters come pre-set to max out at 84 degrees as a safety feature. However, in spa mode it can reach 104degrees.
Jan 11, 2011 | Pentair Mastertemp Heater
Apr 04, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Apr 20, 2009 | Pentair Mastertemp Heater
Pentair Mastertemp Heater Logo
164 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
