POWER HOT TUB
WILL NOT TURN ON
  • 22 Answers
This will need a service from a qualified hot tub specialist in your local area
Posted on Apr 18, 2014
Back to my spaberry hot tub, we have followed all the directions to a t twice and still won't turn on, is there a reset switch? What are we doing wrong?
Hi Karen,
Is the motor turning on? Or no power at all when you turn it on?
I am going to assume that the power is on and the water is just not circulating. If this is the issue you could have an air lock. An air lock is common on a new tub or when you change the water. To remove it you just have to open one of the unions slightly to remove it and your pump should prime.
If in fact you are not getting power to your pump, check your fuse, plug, and cord to make sure they are all working correctly.
Here are a couple articles that may help you as a first time tub owner.
Hot Tub Problems top 10 Hot tub 101
Jan 14, 2017 | SpaBerry Pool & Spa
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
Why won't the spa turn on?
The best way to detect where your problem may be is by testing each unit associated with your hot tub. Start by turning off the main power, now unplug all the accessories on your power pak
  • pumps
  • blowers
  • lights
  • ozonators
  • radio
something is tripping your power pak and this is the quickest way to find out. Turn the main power back on. Plug in each accessory pausing between, when the pak trips you know you have found your issue. It could be as easy as a fuse or a ceased pump.
Once you find out what needs to be repaired you may want to call out a hot tub service professional to repair the unit. Hot Tub Power Pak Repair
Jul 27, 2015 | Pool & Spa
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
How to turn on hot tub
Hot tubs do not have an "on" button. They are preset to heat up to 100 as soon as the breaker is turned on.
May 31, 2009 | Qca Spas Paradise Hot Tub
Hot tub wont stay hot
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on http://marylandhottubrepair.blogspot.com...
May 20, 2009 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
Open Questions:
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
