I have a Yaskawa P150 programmer, which uses two YE DATA YD 645C, double side double density floppy drives. Now both drives' mag heads are bad, The problem is not being able to find parts to repair the drives and the only rededy is to find the useable replacement drives.
Try replace with floppy emulator
Posted on Oct 11, 2014
2 Suggested Answers
  • 10406 Answers
SOURCE: YE DATA PN 134526-41 FLOPPY DRIVE
Go to any computer-store, with your current floppy-drive,
and ask them to sell you a compatible replacement.
Or, browse through "Thrift Stores" for a "pre-owned" one.
Posted on Aug 23, 2010
I have 4 YE DATA YD 645C-1545C drives, any replacement or repair likelihood?
sure.. buy another one.. it is just a flopppy drive. Check it on another computer though to be sure it is not a cable issue or power cable issue.. floppies are everywhere cheap.
Apr 18, 2014 | Computers & Internet
FDD Y-E Data YD-380B Repair RFQ
I have a YE Data YD-380B disk drive. I/O error is appeared when it try to read floppy. How can I solve this problem
thanks
mehrdad
Jun 12, 2013 | Ye Data - yd-380b - Yd-380b 1.2mb 5.25...
Format floppy disks
Disks come in different formats . Double density. Single density Double sided singles sided. You must purchase the disk that your machine calls for.
May 23, 2013 | Computers & Internet
I need a JU-253-403P floppy drive or equivalent
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Mar 05, 2009 | Panasonic (JU257A607P) (JU257A607P)...
How is info stored on a floppy disk
This is how it works,
  1. The computer program passes an instruction to the computer hardware to write a data file on a floppy disk, which is very similar to a single platter in a hard disk drive except that it is spinning much slower, with far less capacity and slower access time.
  2. The computer hardware and the floppy-disk-drive controller start the motor in the diskette drive to spin the floppy disk.The disk has many concentric tracks on each side. Each track is divided into smaller segments called sectors, like slices of a pie.
  3. A second motor, called a stepper motorrotates a worm-gear shaft (a miniature version of the worm gear in a bench-top vise) in minute increments that match the spacing between tracks.The time it takes to get to the correct track is called "access time." This stepping action (partial revolutions) of the stepper motor moves the read/write heads like the jaws of a bench-top vise. The floppy-disk-drive electronics know how many steps the motor has to turn to move the read/write heads to the correct track.
  4. The read/write heads stop at the track. The read head checks the prewritten addresson the formatted diskette to be sure it is using the correct side of the diskette and is at the proper track. This operation is very similar to the way a record player automatically goes to a certain groove on a vinyl record.
  5. Before the data from the program is written to the diskette, an erase coil (on the same read/write head assembly) is energized to "clear" a wide, "clean slate" sector prior to writing the sector data with the write head. The erased sector is wider than the written sector -- this way, no signals from sectors in adjacent tracks will interfere with the sector in the track being written.
  6. The energized write head puts data on the diskette by magnetizing minute, iron, bar-magnet particles embedded in the diskette surface, very similar to the technology used in the mag stripe on the back of a credit card. The magnetized particles have their north and south poles oriented in such a way that their pattern may be detected and read on a subsequent read operation.
  7. The diskette stops spinning. The floppy disk drive waits for the next command.
On a typical floppy disk drive, the small indicator light stays on during all of the above operations.
and if i helped u solve ur problem in any way...please help me by clicking on the fixya rating..
thank you.
Mar 03, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
Copying disskette from hard drive
copy d:\ <path to file> a: <enter>
try that and see if it works
Aug 20, 2008 | Ye Data (YD8V07) Internal Floppy Drive
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
I need to reinstall my driver.
Nov 14, 2007 | Panasonic (r) Ultra-Compact Digital...
Nov 09, 2007 | Ye Data (YD8V07) Internal Floppy Drive
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
