Question about NEC Office Equipment & Supplies
Chat session I can't calibrate my team board wirelessly
How to unlock facebook chat on ebuddy?
if u r unable to start facebook chat on ebuddy,nimbuzz etc..go to ur facebook account add ur new onother mobile number or email to sign in..then remove an older email or phone number ,..
Apr 09, 2012 | eBuddy Messenger
Norton Anti Viruschat session#924238
If your chat session has been disconnected, click on the reconnection email that you got from the Norton support team.
You can also contact them from the toll free number 1800 745 6061
Regards,
Muhaim
Dec 04, 2010 | Symantec Norton Antivirus 2010 - 3 User...
I need to hine My chat tab which ic just below my inbox but I need that back when ever needed . Also I need the chat sessions saved in the chat log.
To hide the Chat tab, you can just click the minus (-) sign beside Chat. When you need to chat, just click the plus (+) sign.
To save the chat sessions, go to Settings -> Chat. Then on My chat history, select Save chat history.
Hope this helps!
Mar 05, 2010 | Google Gmail
When trying to use chat function, the stylus screen malfunctions. For example, if I try to place the stylus on the "g", the arrow jumps across the screen to the "r". Is there a fix for this?
I assume you've already tried to re-calibrate your touchscreen?
If so and the problem still exists, its a problem with your wireless wifi board. You would have to send this in for repair. As it causes for board work.
Dec 31, 2009 | Nintendo DS Lite Console
I have installed my Range Plus Router and I am trying to add my wireless laptop to the system and connect my printer to the laptop I am lost
Hey,
its a pretty complicated process, I'm sure one of our experts could guide you on a live chat session.
but basicly, you need to connect the laptop to the same network as the others are connected to, have a look at the settings from the computer that is already connected to the wireless network and then use the same settings on the laptop, network name etc.
The printer.. it debends.
I'm sure one of our experts can assist you in more detail in a live chat session.
You can also contact geeksquad maybe they could come over and set it up for you.
Thanks,
Ekse
Feb 15, 2009 | Computers & Internet
Trying to hook up dell truemobile 2300 wireless broadband router model wx-5565d
Well dell has ther online chat support team which is only avalibe intell 5 PM during the day only.
Jan 19, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Hi i was chatting with sunny16 and my connection went down
got you again.i have been waiting for your reply.this is what i posted in the last of our chat session.
"the manual does not lead to any safety fuse.So the control board might be damaged, or i guess should be replaced.the control board controls the display too.considering the other case with the door lock, it might be the interlock door mechanism which can be removed once the board is replaced and the machine starts to work,"
i guess you wont be charged for my chat session, but i feel its my duty to help you out as i started this.:).post your further comments here.will look forward to chat with you again.
Jan 11, 2009 | Washing Machines
Not Grinding
Make sure you not get any damp into the grinder.
Best regards
/Mirran
Oct 15, 2008 | Saeco Vienna SuperAutomatica Coffee...
Just installed, papper jam won't turn off,can't calibrate
uninstall the software and install it and upgrade the firmware it will be solved most of the problems
upgrade the firmware from below link
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?downloadStep=s2&selectedDownload=dln00182&operatingSystem=windows_vista&selectedLanguage=es&downloadLanguage=en
download the software from this link and install it....
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=130&CID=go&idhbx=easysharesw&pq-locale=en_US&_requestid=592
sir once we finish this chat you will be asked to rate the chat. that time please dont forget to give a good rating
and review. because many customers dont rate the chat and we experts are left with no credits for providing a
solution.
so please dont forget to rate the chat after end of the session. this is just a information to you. always use end
session button to end the session.
thanks
good luck
Aug 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
MP600R
Sir,
Change the settings of my Airport Extreme back to "Create a wireless network".
Check your airport settings using Airport Utility (if you don't have it just download it from Apple) and look for "Wireless Mode";
Make sure is set to "Create a wireless network".
it is a driver, settings or software version based problem. So try to download latest driver and change the setting of above i mentioned.....
solution.
Aug 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
37 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
