Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Canon MF4350d crooked printing
Printer output is no longer aligned. Paper is in straight. Recent occurrence
SOURCE: printer door open message
Further to this, the sensors can give way. Try soldering or pushing the two connections together. If you need to test, you will have to put the lid back on but you can leave the sensor out of the rinter by draping between the cover and the frame of the putput tray (be careful not to pinch it. AAMOF I leave my sensor out as even though I've pinched it together it has a habit of coming undone.
Posted on Jul 13, 2008
old marine
  • 1973 Answers
SOURCE: Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Posted on Jun 17, 2009
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
  • 4088 Answers
SOURCE: skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
Posted on Jul 10, 2009
SOURCE: My Canon MX700 printer prints crooked--did the maintenance too!
Try printing from the rear tray. My printouts from the bottom tray come out crooked, but the ones from the rear tray seem fine.
Posted on Dec 20, 2009
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Print not came in continues and just one print printer show in print continue in current size Yes or No
open control panel>printers and faxes> right click on canon check output size colunm in printing preferences if it is on match paper size then select it as same size selected in page size column &apply the setting. i'm sure it will help
Oct 04, 2012 | Canon ImageCLASS MF4350d Laser All-in-One ...
My printer is printing crooked
If you mean it takes the paper in crooked then check your paper guides on the intray they need to hold the paper firmly. If they are Ok then it could be the rollers are worn or dirty and need replacement, a local printer repair center will be able to help, most printers are easily to replace the paper pickup rollers. Good luck
Mar 05, 2012 | Canon ImageCLASS MF4350d Laser All-in-One ...
Cannot get black cartridge to print. I've checked everything...cleaned printer head.
Press the Resume/Cancel button.
- If paper is being fed at error occurrence,
the error is indicated after the paper is
ejected.
- If the error occurs, the print head
alignment values are not changed.
- After exit from the error by the
Resume/Cancel button, the automatic
print head alignment will not be re-done
Aug 23, 2011 | Canon PIXMA® MP460 All-In-One InkJet...
My HP Officejet Pro K8600 prints crooked, how do I fix that?
is the paper going thrugh crooked?
make sure the paper is in the tray and the guides are night and straight.
if that is ok, look for something that makes the paper turn crooked by hitting it, such as a lost scrap of paper or a paperclip where it does not belong.
Dec 29, 2010 | HP OfficeJet Pro K8600 Printer
Hi Where do I load the paper in my Canon MX310?
The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals .
I hope this helps.
Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
My Canon MF4350d is printing slightly slanted
Check the paper tray if its properly aligned, and ensure you have a high quality paper for printing, and the paper is not damp
Mar 10, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
The print output on the paper is crooked.
The back of the unit has a piece which pulls off to clear paper jams. It was not fully pushed in. I found the solution on another post that was on your site.
Apr 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Canon MX310 not printing properly
If you are running Windows XP, you should be able to go to Control Panel> Printers and see your printer. Right-click and go to properties. From there you should be able to align the print cartridges and that should fix the problem. If problem persists, contact your manufacturer.
Jan 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
old marine
old marine
