Question about Samsung Tab Tablets & eReaders
Display lights up but there is no picture - Tab Samsung Tablets & eReaders
    Guru:
  • 135 Answers
Try factory reset it maybe a SW problem of operting system
Posted on Apr 19, 2014
My kobo glow is still working but the light isn't - can it be repaired?
I assume you're talking about the light behind the display. It can be repaired, but do weigh the labor cost against the price of replacement. Possible failure causes: bad connection between main board and display, LED driver chip failure, open LED. Best case: somebody didn't properly latch the LED cable connector on the main board and the cable has slipped loose. Worst case: the driver has failed but is not available on the open market, or an LED has failed and the display turns out to be permanently assembled with glue so you can't pull the back off to find and replace the bad LED. (I don't know if this is the case because I've not had this model apart before.)
Feb 26, 2018 | Tablets & eReaders
How do I get a picture that was sent to me on Messenger to my saved pictures?
I'd be more than happy to help. Open the message. Tap the image you want to save. At the top right corner there is a square icon with an "up arrow" through it. Tap that icon. It should open up a list of options. Find the icon that says "Save image". It's a square icon with a down arrow through it. Tap it. The image will be saved to your photos.
Jan 02, 2016 | Apple iPad Mini with Retina Display
The digitlizer screen is cracked but the picture shows and I was wondering if there was some way to work around the Crack until I can get it fixed
To answer your question we need to know what functionality you have lost. If you can not use the touchscreen at all due to the damage, then it will come down to whether your device will support an external mouse or something similar. But your best bet is going to be to replace the display as soon as possible. If the display is cracked but still currently readable, it is only going to get worse, as the LCD fluid leaks through the display portion of the tablet.
I post on behalf of HP.
Jul 23, 2015 | Tablets & eReaders
Ipad mini A1432, I changed the motherboard, display lights without light
You probably know this as you are able to replace a motherboard. The question is confusing. It sounds to me as though your saying your display light either stays on or comes on randomly, this is either a fault in the wiring or the soldering. You will probably have to go back inside the pad.
Mar 19, 2015 | Apple iPad Mini
My new Samsung SM-T310 tablet screen flickers so much I cannot use it. is there a fix?
find out if the actual display or just the back lights are flickering first .
turn on a good flashlight lay it on the face of the display when lights go out if the picture remains then it is the back lights not the display
but either way i believe you will end up replacing the display (backlights included( and probably LEDs) ) i will look at availability and feasability of this, come back with item model number and year
Jan 12, 2015 | Samsung Galaxy TabPRO SM-T320 16 GB Tablet...
No pictures displayed when on internet any ideas anyone
What that means is that some tablet's do not work right what you should do is well there is nothing because inlass it worked when you got it if you did then take it back to where you got it from. if not then you just cant use your table's sorry if that is how it is
Apr 07, 2013 | Samsung Galaxy Note 10.1"
When i power my hp tx2000 it display all lights and the cap light is flashing but there is no display at the screen even it does not boot, what can i do to repair it.
mi computadora tiene un año 6 meses es una tx2627cl ; derepente comenzo a pitar y cada vez que la prendo pita y el lector de huellas digitales no reconoce y esta lenta que hago ayudenme porfa es urgente
Jan 14, 2011 | HP Tablets & eReaders
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Apr 21, 2010 | Gateway M280E
Lenovo X60 laptop display has stopped working
The backlight is broken. These are small flourescent tube lights about the width of a pencil lead. You dropped the laptop and the bulb broke. It will have to be replaced. The driver has nothing to do with your problem, reinstalling it will not get your picture back.
Dec 13, 2008 | Lenovo ThinkPad X60 Tablet PC
DISPLAY PROBLEM
the backlight is broken, call the store you bought it to have it replaced (if it's still in warranty)
Dec 15, 2007 | Fujitsu Siemens LifeBook T3010 Tablet PC
Tablets & eReaders Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
