Mp2816cp how to work this item
  • Cedric Arnold
    Cedric Arnold Apr 18, 2014
    this is not a remote control but some kind of media player
How can i delete items in trash?
Depending on what you are doing, and what computer you are using... click on Trash. A list of items might appear in a panel. Click on one item. It should be highlighted. Look along the top of the panel for a dustbin/trashcan icon and click it. Does that delete the item? Good. Now select all the items in the panel (Ctrl-A often works) and click the trashcan again.
Sometimes you can right-click on Trash and a menu pops up, with an option to Empty Trash - click on that option for a quicker method.
May 14, 2017 | Computers & Internet
Cheat codes for minecraft
Duplication Glitch
Follow these simple steps to duplicate items in Minecraft.
  • Step 1: Put item in your inventory.
  • Step 2: Drop item (More items dropped = more items duplicated)
  • Step 3: Pause and click "Save and Quit To Title"
  • Step 4: Play the world with dropped items
  • Step 5: Pick up items.
  • Step 6: Pause. Wait of the world to save.
  • Stp 7: Exit Minecraft.
  • Step 8: Open Minecraft again.
  • Step 9: Enjoy the duplicated items! (Works with diamonds)
Dec 08, 2013 | Android Apps
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
Hi, I have restaurant pro express v 12.0. Is
You could program a key at bottom with the ON SCREEN KEYBOARD function using the TOUCH SCREEN SETUP. This will let you manually type in the item number or bar code number. One thing to note, if you do not use bar code numbers as your item numbers, you can still make this work. On your inventory screen, click on the green check box beside ALTERNATE SKU. Then type or scan the bar code and ENTER and SAVE. You now have both an item # and bar code # that will reference your items.
Nov 07, 2010 | Pc America Restaurant Pro Express
How to edit my item being sold.I've tried with no luck. From day one i've tried to change my reserve price.I follow the directions,but does not work.I have roadrunner and my screen does not show what i'm...
Hi, If you go to active listings on the right side of your ebay item it will have a drop down menu- relist,edit will be there. You should be able to edit item and change reserve price if this does not work because of time on auction left then you must end item which is in same place and instead of relisting there is sell similar item click this, then fix your reserve. Hope i helped. Lesnbek
Oct 21, 2009 | eBay Auctions
2005 PT Cruiser's back-up lights & rear fogger not working
Most likely the wiring was miss reinstalled, wore through the insulation and shorted, causing the fuse to blow.
Aug 12, 2009 | 2005 Chrysler PT Cruiser
How do I change the font in "Sent Items"?
Hi there.
You can't change the font in sent items because you already sent email in the font you chose to send them in.
If you send them in large font it should show that in the sent items folder.
Jun 12, 2009 | Microsoft Office Professional 2007 Full...
Sold Out items
Greetings Jadon,
Presently we do not have in place a system to notify our customers when an out of stock item becomes available, unless the item had a raincheck issued on it. I would suggest working with your local store and seeing if you are able to order the item in advance. Please keep in mind that there are many items, such as the Wii gaming system, which we are not able to order, and we sell these on a first come, first serve basis when we do receive them.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 26, 2008 | Nintendo Wii Console
Message sending failed
Reason of this Problem:
Actually it happens due to mem full in Sent Items with Pending Status.
Solution:
Just delete one message from Sent Items.
Better if you delete all messages from your Sent Items, as you will face again this problem if again Sent Items fulls with messages having status Pending.
Regards,
Shakir Idrees
Mar 23, 2008 | Nokia 1112 Cellular Phone
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
