Question about Electrolux Dryers
Trying to replace electrolux blower fan asymbly
Have replacement part buy will not go on right. I think i'm doing something wrong
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
First why did you need to replace the assembly? but you may need to send me pictures of what you have so I can see. email them to me at aaahandy@gmail.com
Posted on Apr 19, 2014
How do I replace blower motor resistor?
U are on the right track. But check this out - is the low speed on the blower the only thing that is not working? Could be other things, such as lights that you are not aware of.
On some cars the low speeds for the blower work thru the ignition switch. If something is wrong with the switch the fan will work on high speed only but the lower speeds are inoperative.
Sep 05, 2015 | 2000 Dodge Grand Caravan
Jeep Grand Cherokee 2001 blower fan resistor replacement
Hy almare - I would take it back. Did you buy it from a junk yard and were hoping to make it work or did you buy from auto parts store and they gave you the wrong thing? I would take it back and get the right part . Try another place if they don't have it. Or go yo the junkyard and there. You shouldn't have to jimmy rig that connection. Thanks.
Jeff
Jul 05, 2008 | 2001 Jeep Grand Cherokee
I have a 1994 honda accord lx..heater fan was makin funny noises for a while..then stopped working..started working and stopped again..Is it hard to replace..could it be a fuse..I;m a girl..could I do it...
The heater fan is on the right side floor board under the dash. It is a little tough to do but not extremely hard. If the blower was making noise, it could be something in the heater housing. If it is starting and stopping it is probably the blower motor. When replacing the blower motor you may have to remove the fan from the motor depending on where you buy a new one. The fans (usually made of plastic) break very easy. If you attempt this, be very careful in removing the fan.
Under the dash on the right side you will have to lay on the floor and look up. There may be a lower dash panel to remove. The motor is just below the glovebox. Removed the wire, remove the bolts/screws attaching the blower to the housing. Remove the blower.
Dec 29, 2010 | 1994 Honda Accord
Heater fan works for a while then cuts off till it cools down
What can go wrong with a blower motor?
There are several things that may cause your blower motor to stop working. The simplest cause would be a blown fuse. If you replace the fuse and it quickly blows again, then you probably have an electrical short. Disconnected wires on the exterior of the blower motor can also cause it stop working, and if your blower motor gets dirty, it can get clogged or muddy which keeps the fan blades from spinning.
How do I test my blower motor?
When you are troubleshooting your blower motor, it is best to start by running the air conditioning or the heater to see if you can hear the sound of the fan. If you can hear the fan, it could be clogged or corroded with dirt. If you do not hear the fan, then you may have a bad resistor, blown fuse, or a loose wire. Next, you should replace any blown fuses in your car's fuse panel and try to start the blower motor again. If another fuse blows right away, you have an electrical short. If it doesn't blow out and the motor is still silent, then something else is wrong. In the case where the fuse lasts for a little while as the fan spins but then the fuse blows again, that usually means you need to replace the brushes on the motor. Finally, you can pull the motor out and visually inspect it for loose wires. If you don't see any and still want to test, try hooking it up to the battery to see if the motor will start. If all these tests still find you with a dead blower motor, it's definitely time to replace it.
How do I replace it?
Usually located under your vehicle's instrument panel, the blower motor can be removed and replaced. You'll need to disconnect the blower motor connector and remove the retaining screws holding it into place. Detach the fan retainer clip from the motor shaft that's located in the center of the blower wheel. You may need to save that piece if you are not replacing the whole motor. Inspect your new motor to ensure nothing is broken and the blades can properly spin. Re-attach the fan retainer clip, the retaining screws, and the connector so you can test your new blower motor out.
Dec 13, 2010 | 2001 Chevrolet Silverado 1500
How to replace blower fan in 2004 impala i think the damm thing froze; i put some antifreeze in about 5 mins later the fan kicked in an heard what sounded like ice crumbling in the dash but now only the 2...
If you are asking to replace the blower, because, I think, the way you said, i analize that, the other coil was burn already. I think you are right, replace the fan, but its a lot of work, so I suggest you to buy a manual book, that's the best thing if you want to do it yourself. ok
Dec 29, 2009 | 2004 Chevrolet Impala
Saturn 2000 LS2 Blower Fan Problem
You blower fan obviously works. Try replacing the fan speed switch.
Mar 17, 2009 | 2000 Saturn Ls 4dr Sedan
99 jeep grand cherokee Blower Motor will not stop running ATC
You need to replace the switch which turns your fan speed up and down
Jan 30, 2009 | 1999 Jeep Grand Cherokee
Dryers Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
