Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
My wuxing electric bike is very slow
It will not go any fast,uphill i have to push it.
Scooter bikes
Most motors are housed in the wheel hub. Just look to see where the wiring is going.
Aug 17, 2013 | Electric Bicycle Motor, Bike,electric...
1978 Suzuki GS1000 Battery Dies Out After a Week
Either there is a short somewhere or your starter is dragging.
Jun 23, 2017 | Motorcycles
Lawn tractor loses pull going downhill & then grabs and continues on. Works fine uphill.
it's a safety feature to keep the mower from getting going to fast downhill and out of control
Jul 19, 2012 | Garden
Mobility scooter goes slow
driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
Jan 21, 2012 | Health & Beauty
Hyosung avitar 650 wont stay running
Maybe this will help. This is a common problem that I have had with my GV250. Almost the same bike mechanically by Hyosung.
If the battery is low on charge and you are lucky enough for the bike to start. As per normal when first started it revs higher because the bike is cold, this turns the alternator fast to give you the electricity you need to keep the bikes computer working properly. Bike will warm up and revs drop down, alternater not turning as fast, not as much electricity being made. Bike will either stall or rev up and down irradically to try to produce its own electricity. This will occur when the battery charge is low and bike is at low revs, for example when you slow down for traffic or you stop.
If this is your problem. To resolve it when you are out on the road, keep the revs up, twisting your throttle gently when you are going slow or stopped. Give the bike a good long run on the open road to give the battery some charge from the alternator.
Make sure your battery is maintained. If you dont use your bike for a while it will lose charge just sitting there doing nothing. Give the battery a good deep cycle charge or take the bike for a good long open road ride.
Jun 02, 2011 | 2011 Hyosung GV 650 Avitar
Cherokee just stops. Driving slow, fast, uphill,
Have your timing checked out, and check if you have any MIL codes.
Jul 11, 2010 | 2002 Jeep Grand Cherokee
I just bought a wuxing ebike and i cant get it started the battery is fully changed i turn the key and nothing
the problem might be with the connecting wires or the gear fuse of the switch might have melted down just get them checked. u cant do it all by yourself
Mar 10, 2010 | Electric Bicycle Motor, Bike,electric...
Today suddenly my 4runner 98 V6 started to rattle in a slow gear and when going uphill the car had a sulfur smell but only when pushing it uphill the engine light came on but turned off after 10 minutes...
Take it into your mechanic ASAP before you throw a rod and destroy your engine, check oil level also...DO NOT DRIVE IT ANYMORE or you may be looking for another car soon.
Apr 18, 2009 | 1998 Toyota 4Runner
Electric start on 640 pulls dead
put bike into 2nd gear while on the bike and push backwards until the bike goes no further.put back into nuetrual.should start easier.works on my 640 when its slow to start
Mar 29, 2009 | 2002 KTM 640 LC4
Bighorn Trans
The Bighorn auto tran smission is a special transmission with a snow or uphill assist function. When you use this function it will definitely go fast into Overdrive when shifted upwards.
Willy Baguio City
92 Irmsher 3.1
Oct 16, 2008 | 1998 Isuzu Trooper
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
46 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
