Question about Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Alarm stay led on (Intermittent)
Coffee is grinded then the alarm led "!" will stay on. I did bring the machine to a service center, but the guy keep changing part and problem is unresolved. The guy told me that he was able to do 20 coffees in a row. I'm not able to do 4 in the same sequence. The O'ring seal on the piston has been change A microswitch has been changed Adjustment on the grinder The service man told me that my coffee is probably to greasy. Did try with another one, same problem. True that my original coffee was very oily appearance, still we did use the same coffee for the last 5 years. Is there a way to do a diagnostic to read witch sensor is causing the problem? Is there a way to reset the machine to it's original state. Maybe the logic is self adjusting and for whatever reason the program is loss Any help appreciated
    New Friend:
  • 3 Answers
Martin
Try to clean the water flow sensor
See more diagnostic option in the following picture
you should see the pump flow meter light in pulses -
if not check / clean the flowmeter and its contacts / connector
see more diagnostic in chapter 5.1.1 of the service manual
can be founed in the following link
http://www.partsguru.com/user/SERVICE%20MANUAL%20TALEA%20ODEA%20REV.03%202.pdf
Saeco Odea Giro Alarm stay led on (Intermittent) - 339214ff-6391-43d7-b895-d561e23fde5c.png
Posted on Apr 19, 2014
  • 5 Answers
I assume you tried to clean and oil the brewing block. This is a great video to diagnose your Odea:
https://www.youtube.com/watch?v=ftOWLMhmpjU
Good luck.
Testimonial: "Uccio, Thanks for your help. Will look at the video after this post (probably I have seen it :) )Yes I did cleaned, very often, and greased the block. Once in a while, I disassembled the block to thoroughly cleaned it and grease. As mentioned, the machine was bring to a service center, 3 time. Worked properly there but after few coffee at home the problem resumed. The guy told me that probably the machine is sensing that not a good amount of coffee has been grind. Did clean the coffee bean container, the coffee funnel with a cloth and alcohol. Did try another coffee brand, Problem remain."
    New Friend:
  • 24 Answers
Can you prime the water circuit? If not, chage the turbine low behind. A second solution is to verify the water sensor level, near the turbine.
Testimonial: "gvincentiu, Thank you for your help. Yes, I.m able to prime the machine. I'm able to use the steam spout. The initial cleaning when open up is normally done, so I suppose the water sensor is properly doing it's job. Yesterday night, I did the descaling process steps. Will see if it help. It would be great if I was able to get a diagnostic code that would pin point to the problem when it occur. Have a good day and a good coffee (you lucky guy :) )"
  • 3 more comments
  • gvincentiu
    gvincentiu Apr 19, 2014
    Trey to test all major components:
  • Martin Theriault
    Martin Theriault Apr 19, 2014
    Hello again gvincentiu. I did all the test and coffee maker pass all of them. The machine made the problem once this morning. After, I was able to brew 4 or 5 coffees. I did play a bit with the grind size. I can't say if it will resolve the problem
  • Martin Theriault
    Again, the machine grind the coffee, then stop before initiating the movement of the brew unit ( raise to the water drip metal plate) and starting the water pump. Meaning the error when I get one is probably at the end of the grinding process.
  • gvincentiu
    May be the grinder is fine, and the problem is at next step: did you try to reset the brew unit?
  • Martin Theriault
    Martin Theriault Apr 20, 2014
    Gvincentiu, Yes I did reset using a magnet and a screw driver
Right red light is blinking all the time
Alarm LED:
• Permanently on (one or more causes): No coffee left, water tank is empty, empty the residual water
tray is full (in this case the dreg drawer also has to be emptied to prevent problems).
• Flashing slowly (one or more causes): Brewing unit is missing, dreg drawer has not been inserted,
coffee container cover has not been inserted, service door is open, rotary knob for opening the hot
water / steam is not in the right position.
• Flashing rapidly:Ventilate the water system
Nov 09, 2014 | Saeco Odea-Giro Espresso Machine
Saeco odea giro flashing light
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not
inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed,
the service door is open.
•on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Odea Go
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Red alarm flashing
The flashing indicator light means something needs to be refilled or emptied.
Oct 15, 2008 | Saeco Odea Giro Espresso Maker -...
Saeco Odea Giro alarm light on all the time and temp light off
Make sure everything is fitted in place, there are several sensors that can bring the lamp to light. I have not heard that the water sensor is gone on Odea machine.
Can the machine run the selftest and can you see any water come out?
Jul 13, 2008 | Saeco Odea Giro Espresso Maker -...
Saeco Odea Giro Plus Coffee Maker Logo
406 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
