Question about Car Audio & Video
Boss bv99651 the red, yellow, and black wires were pulled out from the plug in part of the harness. need to know where they go
SOURCE: 16 pin innerconnecting cable
i just went through that same problem, with the pins disengaging from the clip itself. if you reuse the same plug, it might come out again when its installed. my solution is just to get a new wire harness. i got my's for less then 20 bucks shipped to me.
Posted on Oct 15, 2008
SOURCE: kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Posted on Oct 26, 2008
SOURCE: the wiring on the 8 pin harness has come apart
Red,black,orange,pink. bottom is yellow,hole,green,light blue/yellow
Posted on May 17, 2009
aouate3
  • 123 Answers
SOURCE: the harness of my jensen dvd/mp3/wma receiver the
by the red, i doubt it goes under
Posted on Jun 14, 2009
SOURCE: need to know wire color code
Yes RED is +5 Volts, BLACK 0V BLACK 0V YELLOW +12V. Thats it
Posted on Mar 13, 2010
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Boss diagram
the 2 power lines to supply batery and black to ground blue to speaker
Jun 07, 2014 | Computers & Internet
Im trying to rewire and hook up a boss bv8724 in my 2009life dodge charger. The colors of the wires are not the same except for the red and yellow wires. I connected red to red and yellow to yellow. I...
I recommend you purchase a wiring harness. RCA output should be on the back of the unit (red and white plugs). Remote wire is probably blue running off the back of the unit. You can purchase a harness at www.crutchfield.com it will have the color codes on the packaging and allow you to just "plug" you radio in, once you hook it to the harness of course.
Aug 28, 2011 | Car Audio & Video
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I dont know what gos to what
Radio 12V- white/yellow
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
Jun 08, 2010 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
I need help installing a new radio.
Hi my names Josh and yes you will need a harness if you havent allready purchased one. Plugging your new harness in is very easy and from there you just follow the colors from the new harness to the colors on the harness wires coming out of the new car stereo reciver Red with red yellow with yellow black with black. white with white gray with gray make sure you pay attention to the white and gray wires they are marked one with stirp and one without one you want to put white with stirp toegether with the white with stip on your harness like wise with your green and your purple
Mar 02, 2010 | Buck Saturn Sc1 Sc2 1996 1997 Radio...
Need main wiring schematic for 2000 ultra classic speedo,speedo reset ,tacho, wiring wires got pulled out of plugs need help.thank you
Looking at the plugs on the meter side of the harness: for the speedometer there is a three position plug. Pin #1 is Orange, Pin #2 is White/Green and Pin #3 is Black. for the Tachometer there is a six position plug, Pin #1 is Orange, Pin #2 is Pink, Pin #3 is Black/Yellow, Pin #4 is Green/Red, Pin #5 is Yellow/Red, Pin #6 is Black
Jul 19, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
I need electrical plan for pluging my radio ,for toyota echo 2005
If you are attempting to install an aftermarket radio Don't butcher the plugs on your Toyota ... simply go to a car stereo shop and buy an adapter plug for $10-$20 then wire it to your new radio ... then just plug them together (the wires on the adapter are marked) You'll likely need a dash kit too ... save yourself from a lot of frustration time and money! ....
May 08, 2009 | 2005 Toyota ECHO
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
I need to know what colors mean what, so i can hook my cd player up
Red - Power
Yellow - primary power must be joined to the red
blue - Remote
Black - ground or negative
To find your speaker wires check the color of the cord behind each speaker than match it with the same color in the dash.
or the easy way is to use a normal 1.5v penlight battery and try each speaker cord behind the dash and listen to which speaker give off a crackling noise so you can get the balance on the cd player right.
If u trying to find power in the car and don't have a tester than get a 12v light or bulb join the negative to the body and push the positive wire into each one of the holes in the factory plug in the dash one at a time until the light comes on. That is your positive the rest is easy. (DIY guru)
Oct 09, 2008 | 1991 Honda Accord
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
