Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
LZ 450 dose't work. All LEDs on door are OFF.
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Tip
Porteus on a MultiBoot USB Flash (Grub4DOS)
Porteus is a linux distribution customized for USB flash
and disks (live mode)
It is available as 64bit and 32bit solution
to install on USB flash, CD, MP3 player, camera and hard drive.
Porteus 32bit
1.) Download the Porteus 32bit ISO image:
http://porteus.org/index.php#
2.) Create a folder porteus on a USB flash drive.
3.) Take from the downloaded ISO, files
vmlinuz
initrd.lz (from the folder boot)
and all content (from the folder porteus)
will be placed in a folder porteus.
(extract the files from the ISO can programs Ultra-ISO or WinRar)
4.) In the main menu.lst add a:
title Porteus ==>
configfile (hd0,0)/boot/menus/porteus.lst
5.) In the folder /Boot/menus/ (Create a folder on a USB flash drive)
to file porteus.lst (Create a file on a USB flash drive) add:
splashimage (hd0,0)/BOOT/Splash/slacktux.xpm.gz
foreground 000000
background ffffff
timeout 30
default 0
title Porteus Graphics mode (KDE)
find --set-root /grldr
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 fromusb
initrd /porteus/initrd.lz
title Porteus Graphics mode (KDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE)
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (KDE) + Save changes /porteus/
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 changes=/porteus/ fromusb
title Porteus Graphics VESA mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=telinit~4 fromusb
title Porteus Text mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw fromusb
title Return Back <==
configfile (hd0,0)/menu.lst
title Reboot
reboot
title ShutDown
halt
5.) Download file
http://dl.dropbox.com/u/4040651/slacktux.xpm.gz
Put the file in a folder /Boot/Splash/ (Create a folder on a USB flash drive)
6.) Porteus on our MultibootUSB flash-is ready for operation.
INFO: MultiBoot USB Flash - Survival Guide (Grub4DOS)
http://www.fixya.com/support/r8170992-multiboot_usb_flash_survival_guide
on Feb 07, 2011 | Computers & Internet
My srm - 450 the light is busted where can i get one ?
Any electronics components store.
I replace mine using a blue led from my kids broken toys. Remember leds have polarity, check it before. And always power off the speaker, I did blow some motherboard circuits while testing led and an unplugged horn cable did breakdown voltage. Shame on me
Oct 06, 2014 | Mackie SRM-450 System
Mackie SRM-450 All LEDs on
Some of the +15V/-15V is missing at power supply and this is a good starting point, let me know if i can help you more.
Oct 20, 2011 | Mackie SRM-450 System
My dsr450 has a error when I put in a mini dv tape, but it's working fine with the bigger tape?
um what is the brand of mini dv tape you are using, sonydvcam tapes are best and also what dose the error on the 450 say.. It usually has an error followed by a code number and you can use this code number to find out what is wrong with it..
Jul 19, 2011 | Sony DSR-450 DV Digital Camcorder
RCA inputs not working on LZ-1100
Push the input souce select buttons on the front of th unit to select the proper input.
Twist the jacks into the amp to remove any corrosion on the terminals or the cables.
Good luck
Jun 21, 2011 | Technical Pro LZ-1100 Amplifier
I have a fisher 909 receiver and it has no sound the speaker a/b button dose not work both leds off help please
Do you have a headphone plugged in? Or maybe it THINKS there is one. TRY headphones.
Mar 26, 2011 | Audio Players & Recorders
How can I see that my jump starter is full loaded ?
there is a 5 led indicator on the jumpstarter 5 leds is full, no leds is empty maybe switch it on for indication
Feb 12, 2010 | Black & Decker Jump Start System 450 Amp...
I have in the Ricoh copy printer
I just looked back at my analog manual. I think you have a different machine than you listed - maybe an FT3713, FT4018, or similiar.
You have a scanner problem:
Possible Causes -
· Scanner home position sensor failure
· Defective scanner motor
· Defective main board
· Defective dc power supply board
· Incorrect scanner drive wire position
· FU202 on the dc power supply board open (blown fuse).
Mar 18, 2009 | Ricoh Aficio 450 Copier
Rcu 450
The book says the following should work for JVC TVs 012 013 054 060 065 066 067 123 157 158 159 182
Apr 20, 2008 | Televison & Video
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
13 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
