Question about Brother HL-2040 Laser Printer
How to get a report on ink level on brother 2240
2 Suggested Answers
  • 8068 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
Brother MFC-J6510DW maintenance mode report
unless you see anything in the report that says, "incompatible ink" then there's nothing else to worry.
Feb 13, 2018 | Office Equipment & Supplies
Brother HL 2240 ready light it on, call for print but nothing happens.
if you press the GO button 3 times very quickly (1-2-3) and you get a printout from the printer then the most likely reason is problem with the connection or the windows driver
Aug 20, 2013 | Brother HL-2240 Monochrome Laser Printer
I have a lexmark x5495, what is the file that that moniters and reports ink levels? It is what stops me from being able to use my own refilled ink cartridges.
Hi there
Lexmark and Brother printers has made the pritners this way so it can not use refills.
You can not reset the inks that I know of on a Lexmark sorry.
All the best Pineworks
Mar 19, 2010 | Lexmark X5495 All-in-One &USB...
Toner light flashes after new cartridge fitted
Try to Reinstall the drivers Remove the Ink Cartridges and insert again.
Feb 12, 2010 | Samsung ML-2240 Laser Printer
Printer will not print. It is connected to the computer with a USB and it is connected securely. It is not correctly reporting ink levels even though I replaced the empty and the low one . It still shows...
most of the inkjet printers are like the same problems. when you are replace the cartridge use origional. dont use gray and refill cartridge. the printer head sensor cannot regognize these kinds of cartridge. so if u use the origional one it will show the ink level.
Dec 01, 2009 | Brother MFC 240C All-In-One InkJet Printer
Hope it helps.
Sep 03, 2009 | Brother MFC-9440CN Laser Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Brother ink monitor not working
There could be a posibility that you may be low on ink. The reason i say this is that you say it prints green. Green is blue and yellow. That means that your red is empty or dried out. If you are low on ink you will have a low or no ink indication and sometimes the software for the printer only has 3-5 diffrent indications.What i mean is when you see the data for your ink there are diffrent levels that it shows. Your software may not be able to diffrenciate between the colors just the status of say one color in your case it could be red.Therefore it would read 0% of ink avaliable but still be able print green. If i were you I would buy a new ink cartridge and see if you get the same results.
Sep 19, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
15 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
