Question about Sirius Satellite Radio Receiver
No signal on my xmp3i receiver - Sirius Satellite Radio Receiver
FIX A XM PORTABLE DEVICE
Does it do anything? Show any signs of life
Feb 14, 2013 | Sirius Xm Xpmp3h1 Portable Satellite Radio...
Sirius sl100 sl 10 how much to repair? Steve.merkli@gmail.com 571-221-2969.
Honestly it will cost anywhere between $60-$100 to repair depending on the Issue. Less expensive to replacein my opinion. The problem is they are discontinued so you can more or less buy one on ebay for around $60 if you can find one. Sirius' alternative is the Pioneer XMP3i u can pick one up at Best Buy or the like retailer for around $199.
Feb 29, 2012 | Car Audio & Video
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a replacement xmp3H1. I had best of serius service on the old radio and recntly renewed service. Now I can't get best of sirius service even though I paid for it
Turn on your XMP3i radio and place it where you have an excellent signal, and power, so you're not relying on only the battery. Tune the XMP3 to Channel 0 to get your serial number, write it down, then tune the radio to Channel 1 and leave it there. Then, call XM Customer Service and explain that you're paying for B.O.S. and then ask XM to send a 'refresh signal' to your radio - that might take a half hour or so, but it should then add the extra channels that you're paying for. Ask then how long to leave the radio on Channel 1 and they'll let you know. Good luck, and let me know how it goes for you. Happy New year too!
Nov 05, 2010 | Audio Players & Recorders
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Aug 21, 2010 | Panasonic PT-AX200U Projector
Receiver does not recognize AM/FM signal.
From what I know all receivers need an antenna, there should be a connection in the back for one. Sometimes you can just use a piece of wire if you live in a large city.
Nov 28, 2009 | Kenwood 104AR Receiver
I recently bought a Garmin 200W Widescreen satnav. I have tried and found a satelite but each time when I take back indoors I loose it, is there anyway to lock the signal in after acquiring.
Hello snippey,
Global Positioning System satellites transmit radio signals which are received by your GPS receiver unit. Your GPS receiver uses these signals to calculate its current location, speed and altitude.
The GPS is not able to perform these calculations unless it is actually able to receive the radio signals from the satellites. Radio signals can be blocked by obstructions such as tall buildings, heavy foliage, tall hills and mountains, etc. Anything that prevents your GPS receiver from having a clear view of the sky will affect it's operation. This includes attempting to use the unit indoors or inside of a vehicle without an external antenna.
There is no way to "lock" the signals in. The GPS simply must be able to receive the signals and in order to do that it needs to be able to "see" the sky.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jul 03, 2008 | GPS
Sirius Satellite Radio Receiver Logo
35 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
