Question about Echo Pb403 Pb413 Pb460 Pb4600 Carburetor Zama C1m-k37d 12520008563
Echo pb4600 won't run with choke open - Echo Pb403 Pb413 Pb460 Pb4600 Carburetor Zama C1m-k37d 12520008563
4 Suggested Answers
  • 320 Answers
SOURCE: echo pb500 only runs with choke open
I'm not to sure about the question. But you say it runs with the chock open. Your engine will only run with the chock open. Can you clarify?
Posted on Mar 05, 2012
SOURCE: echo pb500t stallas when choke is opened
might check the exhaust port and muffler spark screen
Posted on Jul 19, 2012
hunter19_46m
  • 7482 Answers
SOURCE: PB 200 Echo only runs on full choke. Won't prime. I replaced everything in the carb and a new filter and lines. Getting air somewhere.
Hi dbooth
Make sure your fuel lines are connected correctly.
Check the drawing below
Please rate me
Bud
Posted on Oct 11, 2012
My Echo SHC-212 floods out and will not start. Even with no choke and throtle wide open it will still flood cylinder. I have good spark.
Check your choke prime bulb and carburetor lines - sounds like its clogged and gas is barely leaking into flood the cylinder
Jan 25, 2013 | Echo Garden
Pb-460 no spark
u could have a bad magneto, or u may need to check the gap on the magneto and the gap on your plug. pull plug and insert plug into wire and rest on top of head an pull starter to see if u get spark. if not, u need to check your magnetos gap.
Nov 04, 2012 | Echo Pb403 Pb413 Pb460 Pb4600 Carburetor...
Echo pb500t stallas when choke is opened
Jul 19, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
ECHO PE- 200 won't stay running
Check and replace the impulse line if you haven't already. How did you set your carb screws after the rebuild? Start with them lightly seated and then give each a 3/4 turn out to get yourself started.
Mar 17, 2017 | Sewing Machines
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo pb500 only runs with choke open
Feb 27, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
Never used weed wacker before I have a Echo SRM225 how do you start the darn. thing..? :) I have pulled and pulled and no I am not out of gas. :)
You need to put it in full choke. If it is in full choke and still won't start, try pulling the trigger a bit. once you have it started in full choke, back it down to half choke and hold down the trigger until it catches. Once it catches take the choke off entirely WITHOUT removing your finger from the trigger.
May 20, 2011 | Echo Garden
INSTALLED NEW CARBURETOR NOW WILL NOT START?
Assuming all gaskets and lines were installed properly, try priming it with a little gas directly into carb, or remove spark plug and put a little gas directly in cylinder and see if it picks it up. Sometimes for first start this is necessary.
Oct 05, 2010 | Echo Back Pack Blower Pipe Kit Pb4600...
Echo Pb403 Pb413 Pb460 Pb4600 Carburetor Zama C1m-k37d 12520008563 Logo
47 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
