Question about JVC AM FM CD DET FACE CAR STEREO
Jvc car stereo warning wiring chk then reset unit
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 135 Answers
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Posted on Aug 05, 2014
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
  • 87 Answers
SOURCE: I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 04, 2009
81vasquez
  • 34 Answers
SOURCE: left side of unit gets dangerously hot
this is normal that is a heat plate it is designed to get hot and to pull the heat away from the other components.
Posted on Jun 07, 2009
SOURCE: iPhone to JVC KD-S690 Cable Connection
First step: pop a huge one.
Posted on Jan 27, 2010
JVC Car mp3 model, KD-X100 complaint is check wiring. I do power cord detached and reset it lam also detached the protect pin of audio IC from the circuit But can't solved Please give me a remedy
Suggest you CHK WIRING. This would include all wiring connections between unit and vehicle, including connections to speakers and/or external amp.
Aug 15, 2016 | JVC Car Audio & Video
My kd-r446 show on dispay warning chk wiring than reset so how do i reset ?
Hi Divyesh
to reset your stereo, remove the front panel, and look for a small hole to roughly the left hand side of your unit, use a paperclip or something small you can put in the hole, press for about 5 seconds and it will reset the unit to factory settings..hope that helps you..
Dec 17, 2014 | JVC Car Audio & Video
Locked
Remove speaker wires and try to reset. If it resets ck wires for a short.
Apr 21, 2014 | JVC AM FM CD DET FACE CAR STEREO
Cant reset car stereo
my name is larry i have a 1999 gmcyucon and it stuck in 4 hi,
Feb 19, 2014 | Cars & Trucks
How do i reset jvc cd receiver it shows warning chk wiring then reset
May be a wrong model. JVC started this feature in 2009. Your model is older than that.
Aug 25, 2013 | JVC KD-PDR31 CD-ReceiverĀ -I-Pod...
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
Every time i use my car I need to reset my CD receiver KD-R311 jvc
This unit is not installed properly one of the power wires should be on a always hot connedtion the other through the ignition .
Jan 04, 2011 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC AM FM CD DET FACE CAR STEREO Logo
522 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
