Question about JVC Car Audio & Video
Warning wiring chk reset unit - JVC Car Audio & Video
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Speaker wire shorted?
Posted on Apr 19, 2014
JVC Car mp3 model, KD-X100 complaint is check wiring. I do power cord detached and reset it lam also detached the protect pin of audio IC from the circuit But can't solved Please give me a remedy
Suggest you CHK WIRING. This would include all wiring connections between unit and vehicle, including connections to speakers and/or external amp.
Aug 15, 2016 | JVC Car Audio & Video
My kd-r446 show on dispay warning chk wiring than reset so how do i reset ?
Hi Divyesh
to reset your stereo, remove the front panel, and look for a small hole to roughly the left hand side of your unit, use a paperclip or something small you can put in the hole, press for about 5 seconds and it will reset the unit to factory settings..hope that helps you..
Dec 17, 2014 | JVC Car Audio & Video
Jvc car stereo warning wiring chk then reset unit
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Apr 18, 2014 | JVC AM FM CD DET FACE CAR STEREO
How do i reset jvc cd receiver it shows warning chk wiring then reset
May be a wrong model. JVC started this feature in 2009. Your model is older than that.
Aug 25, 2013 | JVC KD-PDR31 CD-ReceiverĀ -I-Pod...
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
2004 FLHTCUI ULTRA CLASSIC..TRYING TO WIRE UP FOR TRAILER..SHORTED WIRES NOW NO BRAKE LIGHTS OR TURN SIGNALS, SPEEDO OR TACH. TSM???
chk backwards to your turn signal control unit. The brake lights and rurn signals are routed in a way that would affect each other.Is this a four wire or?Chk fuses 1st. Good Luck- -Ned- A good grd is important.
Jun 01, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
My turntable will not rotate. I've checked the piece underneath and it appears to on correctly.
it could be be bad turntable motor.to chk this open up the bottom plate by removing the screws around it.then disconnect the wire connector from the motor.start the unit and chk the voltage with multimeter.if u read voltage then motor needs to be replaced.make sure turntable function is on and not off at the control.if there is no power at the connector then it could be control.chk for any loose wires etc.
Aug 16, 2009 | GE Advantium 120 Convection/Microwave Oven
My dryer throws cold air not hot?
One of three things can stop a dryers element, from heating up. the big red wire going to the motors relay switch could be burned off,that is on the back of the motor itself. two, the element or the wirers conected to it have bad contacts. three the safety thermal cutout devices, have open circuts do to some sort of blockage in the vent pipe.
Jul 28, 2009 | Dryers
LRE30757sp\00 brand new is tripping circuit breaker
check your main/sub panel,you may not have enough amperage to supply this unit,is it larger than your previous unit?chk your total wattage of unit and devide by your input voltage to get the amperes drawn on unit then chk fuses/breakers/wiring to see if they can handle the load
Jul 08, 2009 | LG 30 in Kitchen Series Dual Convection...
Car Audio & Video Logo
93 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
