Question about Dishwashers
Electrolux esf 610 dishwasher - Dishwashers
5 Suggested Answers
  • 1073 Answers
SOURCE: dishwasher wash options
www.frigidaire.com look up your model for a download of the manual
Posted on May 11, 2008
localwonder
  • 6784 Answers
SOURCE: Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Posted on Jun 18, 2009
SOURCE: dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
Posted on Jul 24, 2010
  • 174 Answers
SOURCE: Dishwasher ELECTROLUX ESF 6121 WHEN STARTING
this fault can be the heater which has an electrical earth fault. You need an insulation tester to test it. The heater is accessed from the right hand side and is a cartridge type insert in the flow to the top spray water supply.
Posted on Nov 06, 2010
Electrolux ESF 65010. How can I erase failure code if the problem is solved and start test program?
Here's the manual link
WWW.manualslib.com/manual/602210/Aed-Electrolux-Esf65010htlm?page4#manual
Apr 10, 2017 | Electrolux Dishwashers
The anti-flood system has been triggered on ELECTROLUX ESF 656 how can I fix it?
The anti-flood system has been triggered means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Jul 22, 2014 | Electrolux Dishwashers
Hi, My Electrolux dishwasher ESF 45030 has got locked and the control panel is not working anymore, could you please help me to fix it?
All of the manuals I can find are in a language other than english.
Not much help here.
if there is a child lock under a button or two hold it/ them down for 3 seconds or until you get the controls to light up.
Apr 18, 2014 | Electrolux Dishwashers
I desperately need a 400 mm wide dishwasher - is there any out there?
NO i dont believe so the 2 width of the dishwashers made are
18 inches...450 mm
24 inches..600mm
a 16 inch...400 mm is not one know to be made
Aug 28, 2011 | Dishwashers
Dishwasher ELECTROLUX ESF 6121 WHEN STARTING propels the water, and then stop and blink SIJALICE WASHING AND PROGRAM. PROVERENO solenoid which operates. WHAT IS THE PROBLEM. Thank you, Darko
Nov 06, 2010 | Electrolux Dishwashers
Electrolux ESF 662 no water is taken into the machine
Mine did the same thing. Turned out it was leaning back a bit, so I leveled it and now it seems to be working fine.
Mar 08, 2010 | Electrolux 23 in. ESI602 Free-standing...
Dishwash machine electrolux esf 6121
Mar 01, 2009 | Dishwashers
Dishwasher wash options
May 10, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
