Question about Gateway Computers & Internet
Change what touch keys do on gateway laptop
I want to change what the touch keys do on the left and right sides of the keyboard on my gateway laptop. Is there any way that I can do that?
    New Friend:
  • 126 Answers
It may be possible but i need more details like pc model number and who made the keyboard a label underneath the keyboard may give you that info
Posted on Jun 11, 2014
  • 55 Answers
SOURCE: Notebook Keyboard, some Keys doesn't Work. Replace the entire Keyboard??
Remove the keyboard and check if the cable is plugged into the laptop correctly which is usually not the case. Usually the keys may have been damaged and you may have to buy a keyboard replacement.
Posted on Aug 25, 2007
  • 13433 Answers
SOURCE: Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Posted on Mar 28, 2008
  • 81 Answers
SOURCE: Water on keyboard
Unfortunately you may need to get a replacement or just purchase an external USB keyboard and connect it. This would be the cheaper and easier solution for you; unless it is under warranty.
Posted on Mar 16, 2009
  • 130 Answers
SOURCE: left and right shift key problems on
Have you recently connected a desktop keyboard up to it???
If so you may of pressed Numlock with it a problem on laptops.
Posted on Jul 13, 2009
  • 3940 Answers
SOURCE: On a Gateway laptop, the keyboard always
Press Fn Plus the Numlock key that should turn the numlock off
Posted on Oct 05, 2009
I hav laptop acer brand wea the lfet side shift key not working wea as right side shift key is proper working..i need away out to hav the left shift key wrking
I would replace the keyboard. They are fairly inexpensive from that auction site flea bay and a video on how to do it is available on utube. Search for your make and model with the words 'replace keyboard' after it in the search box.
Dec 23, 2013 | Acer Computers & Internet
My touchpad is unresponsive
Step 1:
Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 19, 2013 | Gateway MX Computers & Internet
Touchpad not working gateway-6825
hope this helps
Sep 16, 2012 | Gateway New P-6000 P-6822, P-6825, P-6832,...
My keys on my gateway laptop is not working right
Your keyboard has a "Numeric Pad" on/off button, in order to compress a full-sized keyboard (with its separate numeric-pad, on the right) into the smaller size of the laptop keyboard.
Press that on/off button, to resume "normal" operation of those keyboard characters that are "multi-labelled".
Jun 16, 2010 | Gateway MT3422 RTL Notebook
I have a Gateway Netbook and many of keys have 3
Bruce, you need to use alt depens on the side if it shown the right side press alt on right if its on left pres alt from left
Apr 28, 2010 | Gateway 2520915 Keyboard
Keyboard on ml6232- some of the keys on the right side are messed up. example press p and get 7, press o and get 6, press i and get 5 please help
You have to thurn this feature off ... look for a key marked "fN" on the lower left side. this switch toggles (turns on and off , alternatively) the key pad imbeded into your keyboard
Thanks for your interest in FixYa.com
Dec 11, 2009 | Gateway ML6732 Notebook
Keyboard stuck in Fn mode, how do I get it out?
Sounds like the "Num Lock" is on, the key should be at the top right hand side of the keyboard, just strike that key and the keyboard should return to normal.
Good luck
Jun 11, 2009 | Gateway Computers & Internet
How do you unlock the numlock on a gateway laptop?
Uncle Buck:
On the bottom of the keyboard and to the left you will see a blue "FN" .
Now locate the "Pad Lock or Key with a Paddle-lock Icon" across the top and to the right of the function keys.
Hold down the "FN" key, press the "pad Lock" key, release both keys.
You should be good to go...
Uncle bobby
Jun 04, 2009 | Gateway 2520915 Keyboard
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Problem with keyboard
Hi
this is a comen problem with key boards what you could try is dissconnecting your keyboard from your PC and restarting you PC when you hear a bleep and a messidge on the screen follow the instructions and replug your keyboard back in another thing you could try is setting your keyboard to the UK setting this might help to
Nov 05, 2007 | Logitech Deluxe Access Keyboard
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
