Question about Honda Electrical Supplies
Honda generator ex 4500 will cut off is switch on the auto throttle
5 Suggested Answers
protek480
  • 1714 Answers
SOURCE: I have a Honda generator model EM3500X with auto
The control board that senses load (current) is not working.It should drop to low with no output current. (nothing running)
Posted on Jul 07, 2009
protek480
  • 1714 Answers
SOURCE: The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
SOURCE: The wires to the auto throttle were cut at the
i have the same problem did you find a solution? anyone know what this is used for min has cut wire under carb and on the auto throttle it will only run with carb wide open i tired the two wires under carb and that just shuts fuel off or on with a needle with 12v applied.
Posted on Apr 06, 2010
hondo73162
  • 132 Answers
SOURCE: honda ex1000 auto idle control
check the spark erestor screen that is behind and in the muffler.
it gets plugged with carbon
Posted on Dec 09, 2011
My Honda EB3500X Shuts off when auto throttle is switched on making me run full throttle at all times. Cause? Solution?
if your engine shutting down, then your auto throttle is working.
when you hit the switch watch the throttle arm move on the carburetor to the idle position,if so you may have to clean the carburetor jet and fuel nozzle ports.possibly this occurs when unit has been stored for quite some time.once jets are cleaned it should maintain idle.
May 31, 2014 | Honda Eb 3500 Generator
Cannot get my generator to run on 220 mode, only runs on 110 when I disengage the auto throttle
There's a short in the 220 circuitry. Check for continuity between the two hot leads, or between the hot leads to ground
Jan 25, 2014 | Honda Electrical Supplies
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
Unit starts with auto throttle off. engaging auto throttle shuts down unit. in past months, pluging in a cord would shut down unit. That is with no tool in use, just plugging into the receptacle.
Hi. There are 2 things that control the Auto Throttle and that is the idle control valve (Connected with black and yellow wires) and the Auto Throttle Unit.
Start Generator
Check for 12VDC on the Yellow wire of the idle control valve. Yellow is positive to any good Chassis ground. If you don't have 12VDC then either the Auto Throttle switch is bad or the Auto Throttle Unit iself.
You can gain access to the Auto throttle switch and again check for 12VDC to Ground on both sides of the switch with the switch on. (It may read as high as 13.8 engine running) If you don't get 12 - 13.8 VDC the the Auto throttle control unit is bad
If you have 12VDC to the Idle control Valve and it does not work perform a resistance check across the coil of the Idle control Valve (both wires disconnected Engine off) Black to yellow should read 3 to 4 Ohms If you have no resistance then the coil in the Idle control Valve is bad.
If you need more help just respond here
Kelly
Feb 09, 2010 | Honda 3000 Watt Portable Generator
Dec 01, 2009 | Coleman Electrical Supplies
Oct 01, 2009 | Electrical Supplies
Generator wirring
The generator output hooks to the transfer switch. It senses the power from gen or land power and switches accordingly to allow power into the breaker panel.
Jun 21, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda EMS 4500 Generator - High Voltage Problem
As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
Mar 31, 2009 | Coleman Powermate Premium Plus 6250W...
Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Nov 27, 2008 | Kitchen Appliances - Others
Electrical Supplies Logo
48 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
