Question about Porter Cable 7800 Drywall Sander With Dust Collection
How to remove sander head to replace springs - Porter Cable 7800 Drywall Sander With Dust Collection
How do I change the paper?
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.Refer more on custom essay writing service
Custom Essay Writing Dissertation Writing Thesis Writing with Free Draft...
Jan 09, 2016 | Tools & Hardware - Others
Can anyone give me the steps to replace in & out rollers on a Ridgid 13" planer? Model # TP13002
On a few Ridgid planers, you can remove the retainer plates that hold the roller's bearing blocks in place without removing the head from the base, on others you have to seperate the head from the base to get at them. The infeed and outfeed rollers are not adjustable in that you don't have to line them up precisely when installing new rollers, they only go in one way. They do install into bearing blocks that 'float' on springs to keep the rollers tight on the wood being planed and there is a difference between the springs on the left and right side. Make sure you install the springs on the same side they came out of. When you replace the rollers you should replace the bearing blocks because they have to work together properly. Check the fit of the old bearing blocks on the new rollers, they should rotate smoothly with no side play. Make the call yourself whether to replace them or not.
Feb 25, 2013 | Ridgid 14673 Tool PLANER, 13"" THICKNESS"
Installing brushes in porter cable 7336
Go on line to porter cable customer service ask for a blow out of the motor of your 7336 assembly 6 inch variable speed sander they will have the parts blow up showing each part with a line going into each area where the parts fit together Good luck
Aug 26, 2012 | Porter Cable 7336 6 Inch Variable Speed...
How to replace the sand paper on skil sander hi speed 439
the skil 439 is a palm orbital finish sander. To replace the paper, pop the springs off the side where they take a 90 degree turn towards the work surface. To replace paper, rip a piece of standard sand paper into quarters, reverse removal and done. It's a pretty nice older sander and yes I have one.
Jul 11, 2011 | Garden
Belt sander Craftsman 315.117150 The spring-loaded bolt that adjusts the front roller has an eye hole into which a spring is fastened to the roller. The eye has broken, consequently I am in need of a new...
Alright, I found the breakdown and it is not a very good one. I think I know the part number that you need, but I would feel more comfortable if you would look at it yourself, because the last thing you need is confusion.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Sander-Parts/Model-315117150/0247/0743000/00013345/00002?blt=06&prst=&shdMod=
You can also purchase this part right from the link. Their picture shows the spring actually attached to a small rod on the ordering page. Let me know if this helps.
Nov 26, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Sandpaper sliding off
there isnt enough tension on the belt, hence the side to side movement. keep tightening the spring until it stops
Jul 22, 2009 | Tools & Hardware - Others
Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Jul 22, 2009 | Makita 9924DB Electric Sanders & Polishers
I need manual for Craftsman 315.11720 belt sander
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
Mar 25, 2009 | Tools & Hardware - Others
Porter Cable 7800 Drywall Sander With Dust Collection Logo
44 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
