Question about Kenmore Sewing Machines
Kenmore electronic sewing machine
Message STOP FOR SAFETY PURPOSES What would this mean.
  • Kenmore Master
  • 1,860 Answers
It's possible that a sensor or computer part of the machine is going bad if the machine has a electronic part to it.
Posted on May 02, 2014
Janome 6600 bobbin will not wind error "stop for safety purposes"
I have a feeling the sensor has been jolted just enough to make it stop. Pretty sure this can be adjusted by the dealer quickly. Worse case scenario, you'll have to replace a sensor.
Feb 25, 2015 | Janome Sewing Machines
My 6003 Elna machine stop and says stop for safety purposes How do I get it unlock from that It wont do anything
This is usually what happens if the bobbin case gets dislodged, its just held in place by a magnet but if you have a jam up, often gets moved out of position. Remove top metal plate, take out bobbin, and have a look at the bobbin case, should be two metal markers or red dotsmfront side that align. Lift the case out by grasping edge and lifting up and towards you, clean underneath with the little brush, remove any jammed up threads, then return case to position, aligning the marks.
Feb 24, 2012 | Elna Sewing Machines
Stop for Safety Purposes ?
I have had this happen to me many times. It really does feel as though the problem is in the bobbin, but it's not. After much aggrivation I took it into the repair shop and found out the thred was comming unhooked on the top not in the bobbin. It still happens all the time but I know what it is now so I just rethred the top.
Sep 16, 2008 | Elna Heirloom Edition 6005
Machine will not run
When I have this problem, I turn the knob back and forth (gently) to try to get the needle to release and lift. I get this error message when the needle has shifted (either in the fabric or from using the machine alot at the needle placement shifts).
check your needle, it probably has shifted a bit.
Jun 09, 2008 | Kenmore 19233 Computerized Sewing Machine
Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
sewman7
May 22, 2008 | Janome Memory Craft 5700
Sewing club member starting sewing with a metal bobbin.
Can't say for sure but besides prefrance, I have never seen a differance between metal or plastic in Janome or Elna.
Mar 06, 2008 | Janome Memory Craft 4800QD
E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Jun 16, 2006 | Kenmore 19233 Computerized Sewing Machine
STOP FOR SAFETY
My Kenmore 19606 sometimes gives me that error message when I am holding my fabric taut (on either side of the foot) and I accidentally exert pressure on the needle (that is, tug forward or back on the fabric pulling at the needle)... I found that when it gives me that message and then pauses for a while, cranking a few stitches by hand seems to "recalibrate" it if you will, and bring it back to normal operation sooner... If you're not a tugger like me... =op =o) Maybe the needle needs replaced? It might be slightly bent, or not screwed in properly..?? Don't know if that helps! Good luck!
Oct 26, 2005 | Kenmore 19030
Sewing Machines Logo
66 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
