Question about Polaroid Cameras
I730 service center numberthe i730 polaroid beeps three times and turns off right after it is turned on
  • 7 Answers
SOURCE: makes 3 beeping sounds then turns off
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Posted on Feb 10, 2008
SOURCE: Polaroid i639
Ok, i just had this problem 5 minutes ago because i dropped my camera. I know, very stupid of me! but i was able to fix it myself, and hopefully you can too.
the problem is your lense. The lense being stuck causes the camera to automatically power off. if you can tell where the lense is stuck (you can usually see because it is jammed and lower than the rest, it slants in that direction) you may be able to pull it back out without damaging the camera. i just did this and i was so relieved!
Posted on May 28, 2008
SOURCE: camera issues:(
I had the same problem, stuck lens, 3 beeps and shutdown. You must get pissed off at the camera first. Then bite the lens, clenching it like pliars (you could probably use pliars too), turn the camera on and immediately start pilling on the lens in the outward direction. The tooth grip unstuck the lens and vot it worked. you can take this solution to the bank.
Posted on Oct 24, 2008
  • 212 Answers
SOURCE: Authorised service center in Hyderabad, India
+(91)-(40)-66048356----call this number this is the service center number for polaroid digital cam its located in :Secunderabad, Hyderabad-500003
Posted on Jul 03, 2009
JackHeath
  • 1049 Answers
SOURCE: Polaroid i834 the camera beeps
There could be something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try helping the lens in as you turn it on, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Posted on Apr 30, 2010
When i turn my camera on It shows the welcome
Try inserting new batteries or fully charged batteries.
Jul 31, 2010 | Polaroid I1037 Digital Camera
My son dropped it now it wont open turn it on it beeps three times and shuts off
Unfortunately, with Polaroid cameras, if you hear (3) beeps and it will not power on; this means INTERNAL FAILURE and it's unable to be repaired.
Oct 05, 2009 | Polaroid i733LP Digital Camera
Beeps three times and shuts off
The lens is jammed. It requires manually resetting. If you in the U.K I can help you out. email me at kiddo242@hotmail.com
Aug 09, 2009 | Polaroid i631 Digital Camera
My polaroid i733 turns on the beeps 3 times then turns off when the sd card is in. i have tried formatting the card and camera but it still is not working any help
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
Jul 25, 2009 | Polaroid i733LP Digital Camera
Nextel i730
take it to a mobile service center and have them assist you further with this
Jun 03, 2009 | Nextel i730
I631 camera won't turn on
Mine dose that too ugh i got new batteries but it didnt work it dose the same thing i am wondering if it is jammed or something
Jun 02, 2009 | Polaroid i631 Digital Camera
My Polaroid camera i631 won't turn on!!
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put press on it to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Apr 04, 2009 | Polaroid i631 Digital Camera
Polaroid i631 digital camera
I have the same camera and the same problem, if you use lithium batteries it keeps the charge longer because regular batteries aren't strong enough. Hope that helps you! :)
Dec 28, 2008 | Polaroid i631 Digital Camera
Pink polaroid i631 camera
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens2_bing.gif is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Jun 14, 2008 | Polaroid i631 Digital Camera
Cameras Logo
18 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
