Question about Pool & Spa
Wiring on a 1/2-1/6 hp ac motor - Pool & Spa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Should be a diagram on the side of motor if not check with who sells them
Posted on Apr 19, 2014
What power setting would be best for my Central AC blower? I'm replacing a 2 speed 1/3hp with a 3 speed 1/2hp.
Your thought process is a little backwards. Have you tested the static pressure? If the ducts are too restrictive you DEFINITELY don't need a bigger motor. Obviously the slowest setting is best.
Jul 31, 2017 | Heating & Cooling
What is the motor hp?
Please see below courtesy of engineeringtoolbox.com
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
where
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
where
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
Feb 03, 2016 | Boating
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
How do i reverse the direction of the 1 hp. motor? switching the wiring, i know. but i don't know which ones
your in cars and trucks,
your also dreaming if the motor is not a DC brush motor.
why not say :
where motor is, in a car? (that be the starter that big)
what motor, do say what it is , where it is and make and model of motor , A.C, DC. or 3phase AC. etc.
May 12, 2015 | Cars & Trucks
H ms steve,trying to make sure my 1 hp magnetek 1725 rpm motor is set up for 230 v...magnetek century ac motor the only numbers I see is 164014 please help
There should be a diagram on the side of the motor for proper wiring. Some motors are dual voltage capable others are either 240 or 120 line supply only. They will not be convertible! So you have to bring in what they are labeled as.
Some times the diagram is inside the cover where you make the external connections for in/coming in supply wires.
Mar 03, 2015 | Pool & Spa
AC condenser motor 3 wires, black,orange,brown. Which is L1, L2 and capacitor ????
The black wire is usually the L1 line connection. The brown wire is usually the capacitor wire, and that leaves the orange wire for the other line connection - either L2 or Common depending on the voltage involved.
Aug 14, 2013 | Emerson Fan Motor & Blade - 1/6 HP
. How do I wire this for forward and reverse use
you can reverse the rotation CCW to CW if you reverse the wiring on the brushes
Jan 09, 2011 | Dayton Universal Ac/Dc Open Motor 1 Hp...
Home ac compressor fan won't turn all the time.
your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd compressor@440volt cap
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
