Question about Sector Watches
How do I set the time on a Sector watch 4500
Cannot set time
Manual for my sector
As there is no manual downloads possible for SECTOR watches, the only solution is to contact SECTOR directly. Of course you can browse all the internet, but I'm quite sure direct contact will save you nerves, time and money.
Here is the link:
http://www.watchservicecenter.it/
Apr 22, 2014 | Sector 210 Expander Black Dial Chronograph...
I need a manual for my sector 210 3253926025A
Here is the link:..
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Setting Analog Hands
    I can't find the instructions for this watch but Casio instructions may be similar, so you could try this:-
    Press the "mode" button until you get an abbreviated message for hand setting mode (HS?)
    When in this mode, I expect that two of the other buttons make the hands go forward or backward.
    Some experimenting will be required. When you have finished, press the mode button until normal operation has been achieved.
    Feb 10, 2010 | Sector 450 2653450035 Wrist Watch
    Where can I get an owner's manual for a Sector 133 Chrono Alarm watch?
    Here is the link:
    Rate, please.
    Jul 22, 2009 | Sector Watches
    Sector adv 1000 setting alarm
    key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
    Apr 14, 2008 | Watches
    Sector 255 need to contact sector
    need help in setting time on sector 550 2653955025.
    Nov 16, 2007 | Sector 2653940025 Wrist Watch
    Watches Logo
    26 people viewed this question
    Top Sector Watches Experts
    staicuma
    Level 1 Expert
    aravind shet
    aravind shet
    Are you a Sector Watch Expert? Answer questions, earn points and help others
