Question about Revlon Health & Beauty
Buy replacement mirror glass set
Where can I buy replacement mirror glass set for the Revlon 9420 Makeup Mirror
  • 452 Answers
SOURCE: Lg Glass/mirror replacement
For screen replacement the best solution is to consult hardware vendor.Doing it urself could damage intrernal parts of the phone
Posted on Oct 22, 2007
SOURCE: How do you remove just glass from drivers side mirror?
I posted earlier that I was facing this same problem and found a sight that said you needed to heat the mirror before you start digging. Got a blow driver and a flat head screwdriver and started prying and the pieces started coming out. Took a bit of effort, but the blow dryer was the key.
One thing, my mirror has the turn signal dots and I believe is also heated. When you start prying out the glass, the glass sits on a black rubber-like backing and that is glued to a thin mettalic looking sheet which has metallic leaders running through it. This is then glued to the backing plate. My guess is these metallic "runners" are the heating elements. You don't want to scrape that up. You want the mirror with the black backing and don't scrape the thin metallic sheet. The blow dryer is again key in getting that to detach.
My vehicle is a late model Yukon and everyone probably won't have this problem.
Posted on Dec 19, 2008
  • 59 Answers
SOURCE: How to replace side mirror glass and frame ? 2002 Chevy astro van
It should snap out and the new one snap in. Most auto glass companies can order just replacement glass from burco mirror. http://brokencarmirror.com/replacement/mirrors/
Posted on Feb 23, 2009
  • 5 Answers
SOURCE: replacing a rear view mirror
You will need to remove the broken glass by prying with a screwdriver/small putty knife. You can apply heat (being careful not to melt or distort the backing plate) if there are area which just won't pry up. Installation of the new glass will depend upon the style of backing plate you may have. The following website highlights them with links to the proper technique on the right-hand side of the page: http://www.burcoinc.com/products/redi_cuts/installation/
Posted on Jun 02, 2009
  • 72 Answers
SOURCE: How to replace passenger side mirror. Glass is
You can usually just replace the mirror, any commercial auto-glass store has the glass you need. sometimes it is necessary to replace the mirror and its backing (a plastic frame which snaps into the adjustable motor) you don't need to replace the whole mirror unless the housing is broken.
Please rate this answer. Thank you.
Posted on Apr 08, 2010
How Do I Put new glass mirror on a 2004 ford territory
Interior or exterior? I have looked up mirror glass for some makes and models. It was just the mirror glass with adhesive backing. You take old glass out of assembly. Remove adhesive backing from new mirror glass and stick it on. I don't know if applicable for your vehicle? Do a web search for mirror glass.
You could probably buy the whole mirror assembly, if you want?
Jun 11, 2016 | Ford Cars & Trucks
Replacement switch
You can buy that switch on ebay auction # 280785858493, three of them for $5.95. it is the same switch and just wire it the same. I bought these and repaired my mirror
Jan 14, 2014 | Brookstone Makeup Mirrors: Magnifying...
BULBS FOR REVLON LIGHT UP MIRROR, THE MIRROR IS SQUARE WITH TWO SIDES ONE NORMAL ONE MAGNIFIED, IT IS IN A WHITE PLASTIC FRAME WITH TWO FROSTED STRIPS DOWN EACH SIDE FOR THE LIGHTS. ON THE BULB COVER IT...
should imagine that the covers just either slide out or pop out ,if i could see it then i would work it out but iam a fella and i dont use these things sorry
Oct 17, 2011 | Health & Beauty
I have a Revlon lighted make up mirror, model # RV-961/RV-961F. I threw away the manual and need a replacement halogen bulb 12 Volt or higher. It has three level of lighting but I'll settle for the...
No!,No!, No!, Not 12 V and higher.
It is a 12 Volt bulb with 50 Watts or lower
Hard to remove bulb. I did and exchanged it and still no light I will buy another mirror. Cheap enough.Bed Bath and Beyond sells them.
Jul 24, 2011 | Revlon Health & Beauty
How do I open the housing of Conair Makeup mirror model BE 103 - I removed the screws but cannot separate the mirror to replace bulb
The two sides do come apart but tend to stick. Pull the magnifying mirror apart from the mirror that is attached to the stand. You may need to budge it a little on one side and then the other to get it to come free, but it will.
Jun 08, 2011 | Conair Chrome Double Sided Lighted Makeup...
Hi my Revlon mirror is not working on the brightest setting the model is 9426U. I am wondering if the bulbs need changing, where to buy these bulbs and how to change them! Thank you
where did you buy this mirror, or was it a gift? I think the best thing to do would be to look up the model number and you may get results. It sounds like your bulbs would need changing if they are dimmer than they used to..
Mar 15, 2011 | Health & Beauty
Health & Beauty Logo
48 people viewed this question
Top Revlon Health & Beauty Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Revlon Health and Beauty Expert? Answer questions, earn points and help others
