Question about Sewing Machines
How do i take my iphone 3 apart? - Sewing Machines
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
You should be able to use a small paperclip in the very small hole on it. If you still have your box that it came in there is a pin in there for it.
Posted on May 04, 2014
Why does the speed of my machine change by it self?
Faulty foot pedal control. If you can take it apart you can lubricate the rheostat with 3 in 1 oil. If not, you buy a new one.
Google
make model foot control
Apr 29, 2016 | Sewing Machines
How do I thread it?
    Unwind about 18" or so of thread and bring it around the backside of the bobbin winder tension disc, wind it around the tension disc one time. Some machines might have a thread guide before this step- if yours does, don't skip it! Be sure to place your thread through all the threadguides on your machine. 3.Jul 20, 2015
    How To Thread a Sewing Machine & Wind a Bobbin - Apartment ...
    www.apartmenttherapy.com/how-to-thread-a-sewing-m... Apartment Therapy
Dec 01, 2015 | Sewing Machines
HOW DO I REMOVE FRONT COVER ON KENMORE SEWING MACHINE
1. Newer machines are more difficult. You will have to find the hidden screws behind little plugs. You just pull out the plugs using a very thin screwdriver.
2. The next trick is to pull the machine apart. Their are snaps to unsnap by pulling. Pull a little on areas to see where the snap areas are holding parts tightly together. You will have to pull hard to get these areas unsnapped. You will get it but it takes a little work. Don't pry with your screwdriver or you will ruin the appearance.
3. The older machines are easier. Just unscrew and the parts come apart.
4. Whichever you are working on use some masking tape to mark the screws or hold the screws in the holes they come out of. If you don't do this you may have a problem when it comes time to reassemble.
Sep 03, 2015 | Kenmore Sewing Machines
My machine is only 3 month old it was working fin then went verry slow every thing is working apart from that.
call the company to check on warranty but sounds like the foot control may be going bad already
Mar 18, 2015 | Sewing Machines
Machine is binding up
New needle, right way around, and thread again from scratch, manual in hand. Make sure you're threading with the presser foot up. Raise the bobbin thread. Start each and every seam thus:
1. Place the work under the needle. Use the handwheel or needle up/down function to drop the needle into the fabric.
2. Drop the presser foot.
3. Hold the bobbin and top thread ends together and take about 3 stitches.
4. Drop the thread ends and sew normally. See also: http://www.picturetrail.com/sfx/album/view/22521551 last pair of photos.
Apr 28, 2014 | Euro-Pro 9105 Computerized Sewing Machine
How do I get my sewing machine apart? I have all the screws out but it's tight around the wheel and I can't get it apart.
i am alwase taking things apart and when that happens i drill a small hole where there is no circuit boards, wires, or machinery and put a flat head screw driver in the hole and peel the two pieces apart
May 28, 2012 | Brother XL-3500
Tension
27 - Complete Tension Unit
28 - Setscrew TP 3 X 6
29 - Hexagonal socket screw 4 X 6
There is no exploded view for this component, so if you cannot confidently restore the unit, suggest seeing a technician, and the next time you take something apart, use a camera for reference, and lay components out carefully as they come apart.even write notes for yourself.
Hope this is helpful, it is the best image available in the Janome Manuals.
Aug 02, 2008 | Janome 1600P-DB Mechanical Sewing Machine
My seams pull apart
Sounds like a tension issue.
Check your tension units and thread guides are clean and free of lint....a rag moistened with methylated spirit (denatured, surgical etc) run between the disks will help.
Normal factory tension setting = 3 for all dials although resetting this style of tension unit is, frankly, awkward, so if it ends up being other than 3, don't worry too much, just write it down somewhere handy.
Start with all at tension 3 and try using 4 different colours of thread and sew a scrap to see the balance of the tensions to more easily locate any that are loose.
Ideally, the 2 needle threads should appear as secure dots not at all "loopy", while the looper threads should meet neatly at the edge and be a firm join without pulling at the edge on one side or the other.
Get the needle threads right first, then small adjustments to balance the looper threads....after a few adjustments you will probably have it back to normal.
If you want any more help with this, just drop a line through the "Contact Us" page at www.bargainbox.com.au
Feb 18, 2008 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
