Question about Cassida 3300 Counterfeit Bill Detector and Scanner
Screen says err
When machine is turned on, the screen displays err? I turned off and let it set overnight then turned back on the next morning still the same thing.
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Ford 2011 Edge speakers don't work following a MS Sync update
You need to take that back to the dealer an not even mess around w/that problem, mam/sir... Good Luck
Jan 21, 2013 | 2011 Ford Edge
After charging my nuvi 1450LMT for four hours, I disconnected it from the power cord and left it overnight. When I turned it on the next morning, I got the Garmin logo, then a white screen flashed on...
How did you charge it? If you did not use a high power USB charger, try that overnight. A USB charger provides a lot more powr than your PC. Leave it plugged in and off overnight.
If that does not work, Amazon sells battery replacement kits.
Apr 09, 2017 | Garmin Nuvi 1450LMT
IPod screen does not display and is all white but plays music
hello, Was someone messing around with the Contrast settings? If so, the Contrast may be set so low that you can't see the information on the iPod's screen. The only way to reset your iPod back to the factory defaults (including the Contrast setting) is to let the battery drain all the way out. Do whatever it takes to let the battery die then let the iPod sit overnight to be safe. Then the next morning, charge the battery and turn the iPod on. The first thing you should see is a screen asking you to select your language. If you can see your screen now, congratulations, this did the trick. If not, you probably need a new screen.
Apr 04, 2009 | Apple iPod nano
Err..message from top displays on my FujiFilm FinePix S1Pro
This problem is caused by the plastic memory card door.
There is a door that hides the memory card on the back of the camera.
The door has a small plastic part on the left side that when the door is closed fits inside the camera.
When the door is open this part is exposed. It is right next to the "^" in "^ PUSH TO EJECT"
If you place one drop of superglue on the top of this little plastic part of the door(when open) and let it dry overnight(LEAVING THE DOOR OPEN OVERNIGHT.)
This will slightly build the plastic up about .05-1mm.
The problem is caused by the plastic part being about 1mm too small, liking resulting from normal wear.
I have tested this, and it seems to have resolved my issue with the S1 Pro I bought on e-bay
John C. Vincent
yellowcaseartist.com
Jan 28, 2009 | Fuji FinePix S1 Pro Digital Camera
# 8 in lcd display ,answering machine ge 29875
An overnight rest seemed to cure it. Context - I have a fax machine also hooked up to it that kicks in when it hears the fax signal. I disconnected it overnight while "resting" the answering machine. When the answering machine returned to normal this morning, I hooked up the fax again. So far so good.
Nov 23, 2008 | GE 29875GE Digital Answering Machine
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Cassida 3300 Counterfeit Bill Detector and Scanner Logo
49 people viewed this question
Top Cassida Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Cassida Office Equipment and Supply Expert? Answer questions, earn points and help others
