Question about Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER
Canaon mp287 error p02
Error p02 i tried the given steps of u not but wrks
How about a P02 Error? Is that basically the same jam error or something else?
http://fix-your-printer.blogspot.ca/2012/07/solving-error-p02-on-canon-printers.html?m=1
May 16, 2016 | Office Equipment & Supplies
How to fix error e05 canon mp287
re -insert the ink cartridge push the artridge locking cover until it clicks into place .
Aug 22, 2014 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Alarm po2 after off the power only 4 print and alarm again po2 then afte off the power again only one and alarm again po2
  • p02 is normal issue clean the purge unit and align carriage plate screw problem is solved
  • Or you are using ciss tank properly fix the ciss tube problem willb solved
Mar 15, 2014 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
How solve error p07 in canon mp287
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
  1. Turn off the printer without pulling the power cord.
  2. Press and hold the RESUME button (Green button), keep holding it and then press the power button, do not let go yet.
  3. Keep holding the power button, now release the RESUME button and then press theRESUME button for 5 times and quickly release the POWER button.
  4. When the printer entered the Service Mode, all LED will stop blinking.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
  1. Insert some A4 paper, the printer will print the result.
  2. Look for "Clear Ink Counter" section, press the "Main" button and wait for the message "A function was finished" and then press "OK" button.
  3. Press the "Platen" button located beside the "Main" button.
  4. Look for "Print" section, press the "EEPROM' button, select "Rear Tray" and pres "OK" button.
  5. The printer should printout the result. That's all, you may turn off your printer now. Sometime you need to press the POWER button several time in order to turn off the printer.
source:http://stepblogger.com/tutorial/tutorial-how-to-reset-canon-pixma-mp287-using-resetter-tool/
Jul 05, 2012 | Office Equipment & Supplies
Riso rz220 ui error code P02-405
Error P02-405 means: The upper-limit sensor does not go ON within 12 seconds after the elevator motor operates in the raising direction.
Jan 20, 2011 | Riso RZ220 Duplicator
Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER Logo
12 people viewed this question
old marine
old marine
