Question about Microsoft Windows 7 Ultimate for PC
Acer aspire pew71
Its offing
  • etrc_new May 04, 2014
    Hi yusuf , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? WHat exactly is 'offing' ?
    4.May.2014
How do I get into my bios when F2 won't work
Try tapping the Delete key instead.
It say here you use F2, but you have to do a complete shutdown rather than a restart. You have to keep tapping as soon as you see a logo or life!
http://community.acer.com/t5/2014-Archives/How-do-I-access-the-BIOS-on-a-Acer-Aspire-V3-571G-9636/td-p/13751
  • How to Manually Reset a BIOS Password for Acer ' Business ... yourbusiness.azcentral.com/manually-reset-bios-password-acer-18989... How to Manually Reset a BIOS Password for Acer. ... Acer: Aspire One 552 Service Guide; Resources. Minicircuits.com: The Prevention and Control of Electrostatic ...
  • How to reset bios password on Acer Aspire 5742 PEW71 ... www.youtube.com/watch?v=aNR7JZYl2PE
    • BY AFTER HOURS TV & PC REPAIR
    • 2 MIN
    • 149K VIEWS
    2014-01-27 · How to reset bios password on Acer Aspire 5742 PEW71 laptop After Hours Tv & Pc repair. Subscribe Subscribed Unsubscribe 4,157 4K. ...
  • How to remove BIOS password for Acer Aspire 57** Series ... www.youtube.com/watch?v=ox57qUf33Es
    • BY SAMIR
    • 4 MIN
    • 161K VIEWS
    2011-05-11 · How to remove BIOS password for Acer Aspire 57** Series ... How To Remove BIOS Password Using CMOSPWD ... Acer Aspire 5532 Bios Password Removal ...
  • How to Reset a BIOS Password on an Acer Laptop ' Techwalla https://techwalla.com/content/reset-bios-password-acer-laptop How to Reset a BIOS Password on an Acer Laptop. Submitted by Robert Ceville. ... If you do not want to use the command prompt to reset the BIOS password, ...
  • Removal of the BIOS password from an Acer Aspireone ... https://www.evolutionelectronics.net/node/42 Acer Aspire One 756: The metal pins (i.e. jumper) are labeled "CMOS". Next to the 2nd memory slot.
  • Remove a BIOS Password - custhelp.com acer.custhelp.com/.../detail/a_id/29353/~/remove-a-bios-password Remove a BIOS Password . How do I remove my BIOS password? ... as charges may be required for Acer to remove HDD passwords. Share. Delicious ; Digg ; Facebook ;
  • Apr 16, 2016 | Acer Aspire Computers & Internet
    I need a driver for acer aspire 5742 series pew71
    http://us.acer.com/ac/en/US/content/drivers
    Feb 24, 2015 | Acer Computers & Internet
    5742g not powering up
    Could be almost anything but does it charge the battery? If it does in may be a processor issue if not there is a power supply issue on the main board. Without detailed information, it will not be possible for you to pin point a faulty component as the main board uses DC-DC convertors and one may have stopped oscillating..
    Jan 10, 2014 | Acer Aspire 5742 Notebook
    Drivers acer pew71
    pew71 ethernet software
    Aug 21, 2013 | Computers & Internet
    Drivers acer pew71
    on device manager you must uninstall wi-fi driver and then install again.if this not solve your problem change the wi-fi card ; on the back of laptop!!!
    May 20, 2013 | Acer aspire 5733z4851 intel pentium...
    Well lastnight i set my laptop down and went to go do somthing for about 10 minutes i cam back and it was a blue screen, not thinking anything about it becuase this laptop has done it before i just powered...
    you need to reinstall your operating system your files are corrupt so it will stay in constant boot mode until you reinstall if it doesn't work let me know
    Mar 04, 2013 | Aspire Acer 7520-5071 Notebook
    Acer Aspire 5733 Series won't start
    For this kind of issue, please follow up the following steps to check:
    1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
    2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
    3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
    For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
    If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
    http://www.chargerbuy.com/intocircuit-acer-aspire-5733-ac-adapter-65w-19v.html
    Nov 29, 2012 | Computers & Internet
    Acer aspire 5742 pew71 u01 motherboard is dead what can i do
    Remove the main battery and power up, no change! the power supply should be checked for correct output voltage, if okay! the DC jack in the laptop is a common source of trouble from no power to intermittent operation, at this point I would recommend having the motherboard evaluated.
    Jun 20, 2012 | Acer Aspire 5742 Notebook
    Acer Laptop pew71 aspire manual
    Hello,You can download your "Acer Laptop PEW71 ASPIRE" manual in Acer website.
    Best regards,InJ3CtOr.
    Aug 09, 2011 | Computers & Internet
    Microsoft Windows 7 Ultimate for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
