Question about Rheem Water Heaters
No water from hot tap - Rheem Water Heaters
  • Rheem Master
  • 5,089 Answers
Why when I turn the hot taps on I get milky water out of the hot taps and its a new HWS Vulcan 250 lit electric single element only 3 months old
Put that water in a glass and let it sit for a couple of hours. If it clears up, it is air bubbles. The old unit most likely had mineral deposits on the elements and they insulated the water from micro heating that creates the bubble. Since the unit is new, the water is in direct contact with the heating elements and micro bubbles are forming on the elements. When you turn the hot water on, the turbulence washes the bubbles out.
Sep 04, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Low pressure coming from Hot Water Tap
Were is the water boiler located.
Feb 20, 2014 | Water Heaters
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
No hot water through hot water tap
More information is needed.
What type of water heater do you have, tank or tankless? Is the unit gas or electric? Is there hot water at the water heater? Are all the taps affected, or just 1 tap?
Add a comment and fill out more information. That will send email, and I will respond.
Sep 28, 2011 | Water Heaters
The hot water tap was loose upstairs, the repair man came and fixed it but now i dont have any hot water, is there anything i can try, or will i have to call a repair man out again !
He probably turned off the hot water at the water tank so that he could disassemble the faucet to repair it, then forgot to turn the water back on. If you have no water at all out of any hot-water tap, then you will find a closed water valve at the hot water tank. If you have hot water at all taps except the one he repaired, then you need to open the valve located under the sink.
Oct 21, 2010 | Water Heaters
WHEN MY WATER TANK IS COLD AND I TURN ON THE HOT WATER TAP THE WATER FLOWS FREELY BUT IF I HAVE THE ECONOMY 7 ON OVER NIGHT THE TANK GETS HOT BUT NO WATER FLOWS OUT OF THE TAPS. I LIVE IN A HARD WATER AREA
You may need to replace the tap.hot water is causing the valve to expand and yours may be using a rubber seal inside which is causing expansion and hence no hot water is allowed through it..Trust me on that..
Aug 27, 2009 | Water Heaters
Hot water out of taps is not very hot.
What is hot? Above 122F causes scald within 30 seconds. Get a temperature reading at tap. Use a candy thermometer if need be. If you want 140F water then your gas valve needs replacing.
In most code areas it is now illegal to deliver tap water over 125F to a consumer faucet.
You may love 140F but you jeopardize kids and Seniors.
Mar 03, 2009 | Honeywell Water Heaters
Water Heaters Logo
109 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
