From my research, I have gathered that it is easier to switch out the circuit board into the unit with the good screen, than to replace the screen. The aluminum tape, which reduces interference between the unit and other electronic devices, can be purchased on eBay for cheap. Many sellers have self-adhesive rolls, or smaller pieces, given one's needs.
It sounds as though you are good with tools and know what you're doing. If you were abvle to remove the circuit board from the unit with the cracked screen, you are obviously able to replace it into the case with the good screen. Although I did do a lot of research for you, I was unable to find detailed instructions that would walk you through the screen removal process.
i ave a tom tom 710. it went dead, but when plugged into the charger it shows green but the screen...
(More)
i ave a tom tom 710. it went dead, but when plugged into the charger it shows green but the screen is blank
Hi my Tom Tom GO 700 has stopped working. I have tried resetting it but to no avail. Is there...
(More)
Hi my Tom Tom GO 700 has stopped working. I have tried resetting it but to no avail. Is there anything that can be done to get this unit up and running again.
I have a Tomtom Go910 and noticed recently that the battery wasn't charging in the car. Now it's...
(More)
I have a Tomtom Go910 and noticed recently that the battery wasn't charging in the car. Now it's totally dead and only the green light comes on when I plug it in to the mains or car charger. I tried the reset button which has worked for me in the past but to no avail.
