Mpc clientpro 434 manual
I am looking for a copy of the MPC clientpro 434 user manual but can't seem to find one. Is there a way to get one without having to pay for it? Any suggestions would be greatly appreciated, thanks!
  • Michael Langan
    Michael Langan Apr 22, 2014
    Thanks for the reply, I found that link but wasn't able to do anything with it on Ubuntu, I pulled it up in V/indows and it worked fine. >.<
    Problem Solver:
  • 15 Answers
Try searching on google, I found a website when I searched.
Link: ClientPro 434 All In One Manuals
Hope it helps,
JD
Posted on Apr 19, 2014
  • 44 Answers
SOURCE: Get My Drivers
The company that built the ClientPro 414 for MPC sold it to several other companies. It is also known as the Mecer Multimedia PC L19IA.
Here are the XP drivers directly from Mecer:
http://downloadcenter.mustek.co.za/list.php?dir=Repository%2FMultimedia+PC%2FL19IA%2FXP%2F
Posted on Jul 01, 2009
twitchyguy
  • 12 Answers
SOURCE: I have an MPC Clientpro 414, in 07 I replaced the power supply.
This is most likley a overheating problem. I work for a company who uses 2 of theese computers for each of our almost 600 stores. As one of the facility support guys, I have seen this time after time. What I do is to remove all the access panels from the back of the computer as well as the HDD and optical drive (they both should slide out easily after removing 1 screw each) and blow the entire thing out with a whole can of air. I also remove the HDD from it's sled and blow it off to keep it cool. Put everything back together and you will be good to go again, at least until the backlight inverter burns out. Good luck!
Posted on Jan 11, 2010
  • 106 Answers
SOURCE: I NEED A SERVICE/OWNER MANUAL FOR A MPC CLIENTPRO
Try following link, looks executive file but after installation it puts up a shortcut to manual on desktop
http://www.mpcdrivers.com/sylvia/Support/Desktop/MANUALS/EMA/EMA001054-01%20Install.EXE
Also, can download from
http://www.mpcdrivers.com/apps/compdet1658.html?ID=11342
Hope this helps..!
Posted on May 20, 2010
  • 44 Answers
SOURCE: where is the battery in an MPC ClientPro 414? How
The battery is fairly easy to replace on a CP414, but you need to be careful to avoid breaking the battery socket.
You will need a small Philips-head screw driver (#1, I think) and a small flat-blade screwdriver (for prying). A pair of tweezers will help too.
1. On the back of the system, remove the cable door. It is held in by 1 screw and wraps around the back/bottom of the system.
2. The battery is half-way under the optical drive. The only way to easily remove it is to remove the optical drive.
3. Remove the optical drive. It is held in by 1 screw near the bottom of the system (not the screw in the bottom-right corner of the back of the system, but the one just above that). With the screw removed you can push on the back of the optical drive by reaching in through the cable door you removed in step 1.
4. The battery has a sticker on it that protects it from shorting against the optical drive. This sticker is important, so save it if you can. If you can't save it, use some electrical tape or similar to prevent a short.
5. Peel back the end of the sticker that is closest to the optical drive frame and gently pry back the metal clip that holds the CMOS battery down. It should pop out fairly easily.
When you re-insert a new CMOS battery, make sure you insert the end under the metal clip first and then push down. Also, make sure it is properly aligned or you will probably break the battery socket.
Replacing the battery is much easier if the motherboard is removed first, but removing the motherboard adds about an hour to the whole process. If you want to go down that route, let me know and I'll give you some help.
--Russel
Posted on Oct 17, 2010
tech4allmen
  • 666 Answers
SOURCE: MPC Computers ClientPro 365 PC Desktop ethernet
Sorry to hear about what happened to your computer. Anyhow, please go to this link http://www.mpcdrivers.com/apps/compdriv2b2f.html?ID=16.
This is where you can get all drivers for your computer. Thank you for visiting FixYa! rating and comment for this assistance will be greatly appreciated.
Posted on May 26, 2011
Where do i get the ethernet driver for my mpc clientpro 414
ClientPro 414 Ethernet Driver >>Click here to download Windows XP Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN DriverClick here to download Windows XP x64 Edition Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN Driver
Oct 21, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Need an MPC ClientPro 155 power supply
For most computers, there isn't a power supply made specifically for each. Take the power supply out of the computer, and find out what type of power supply it is. Search for a new one on Google or eBay. Solution-givers cannot sell you merchandise.
Hope I helped
~Aeoryth~
Dec 16, 2009 | MPC Computers ClientPro 155 PC Desktop
I need IDE adapter for MPC 414. Hard drive to MB,fits in caddy. Appears to be an edge connector?
You can contact Patrick Albright at Tangent, 1-800-342-9388 x1772 they are carrying the MPC parts these days. I just talked to him.
Aug 21, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Powers on MPC comes on screen. One short beep. Hard drive light and another light flicker, then it hangs.
PUT INA WINDOWS DISK OR THE SYSTEM DISK THAT CAME WITH UR CPU AND RESTSRT,,, FOLOW THE DIRECTIONS
May 11, 2009 | MPC Computers ClientPro All-In-One PC...
Need tech support MPC is now defunct
There is a community support forum of former MPC Computer Customers and support personnel at http://mpctechsupport.com You might want to post your problem there.
Apr 18, 2009 | MPC Computers ClientPro 125D PC Desktop
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
