Question about Kitchen Ranges
Kenmore range 9752834a
The number ED-F2- appears on the stove
SOURCE: f2 IS FLASHING ON STOVE AND BEEPER WILL NOT STOP
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Posted on Apr 15, 2009
  • 3 Answers
SOURCE: my kenmore oven is displaying ED F2 whats the
EO F2 is the high temp sensor on the back wall activating. It can be the sensor. The sensor should read 1000 ohms in a bowl of ice water. Mine was a clogged screen on the cooling fan.
Posted on Jan 19, 2010
SOURCE: Kenmore 665-9580 error code ''E1 F2''
What happened I am getting the same error LCD Message.. TX... Steve in Florida
Posted on Feb 14, 2010
  • 949 Answers
SOURCE: I am getting a E2 F2 code on my kenmore electric
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore self-cleaning range, display shows code E1-F2.
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Kenmore Gas Stove model 911.3652191
If you can't get the part you are sunk here, sorry,. I do suggest you go on line and try all the parts sources you can find, get the part number and type it in the search window and see what shows up, if you don't have the part number of the panel then call the repair service and ask for it.
Sep 04, 2012 | Kenmore Kitchen Ranges
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
2 burnt element on front
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 10, 2010 | Whirlpool RF364 Electric Kitchen Range
My stove beeps and flashes F1 after having the stove on for a few minutes
Hi - F1 indicates a fault in one or more circuits on control board. No good news here. Boards range from 150-250$ + install. Usually fail during 'self-clean' or as techs call it- 'self-destruct'. Let me know if info is helpful- Thanks- ED
Mar 02, 2010 | Kenmore Kitchen Ranges
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
What does E1 F2 mean? It just appeared and the oven and stove have been working fine
SEARS/KENMORE
Range/Stove/Oven Manufacturers
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page. The first 3 digits of the model number determine who built it. Roper Whirlpool Caloric Kelvinator Gibson D & M 103
647
835
911
155 106
110
562
665
198 174
960 417
662
628 253 587 GE Speed Queen Maytag Litton Toshiba Fedders 363
362 651 925 747 562 484 Amana WCI Tappan Jenn Air 596 790 791 629 i dont see 950 are you sure not 960?
if 960 then temp of oven is too hot and sensor needs attention
Feb 19, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
My kenmore oven is displaying ED F2 whats the problem?
So is mine, although I thought it was E0 F2. Everything I can find says to replace the electronic oven control. My oven did this about 6 months ago and I saw something online that said to unplug the oven, push each button to see if one is stuck, and then plug the oven back in. This worked for me previously, but hasn't worked this time.
Jan 08, 2010 | Kenmore 92022 / 92024 / 92025 / 92029...
Where are the fuses for the oven broiler on model # 9752834A
naps is asking oven element is not working or starting dosen't light up
Dec 07, 2009 | Stoves Ovens
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
